Share |
 Leonhardt Roadster
PostSubject: Leonhardt Roadster   Sun May 01, 2011 9:59 am
Found this while looking at the Gunbus -
Quote :
Technical Data
Engine
* 12 cylinders, 90 degree V-engine, aluminium construction
* Double overhead cam shaft
* 2 valves per cylinder
* Piston capacity: 29.33 liters, 1790 cu inches
* Engine power: 1000 hp, 735 kW
* Maximum engine torque: 2250 Nm, at 2200 RPM
Mixture control
* 12 single throttle valves
* Sequential fuel injection, lambda-controlled
* Regulated catalytic converter
* Dual ignition
* Electronic engine management
Transmission
* ZF 6-gear manual transmission, sintered metal clutch
Dimensions and weight
* Total length of vehicle: 4820 mm
* Width: 1850 mm
* Wheel base: 3600 mm
* Height without windshield: 1300 mm
* Total weight: approx. 2300 kg
Chassis and bodywork
* Steel tube frame with aluminium car body
Axes
* Front: double A-arm with cross flat spring
* Rear: solid axle with interlock and flat springs
Brakes
* Front and rear: disc brakes; 410 mm diameter; 6 piston brake calipers
Tires
* Front: 40” diameter
* Rear: 43” diameter
Technical data are subject to changes.
http://www.leonhardtweb.de/en/index.html
Leonhardt Roadster
» 2015 Build off entry - craftsman t-bucket roadster
» Troy Bilt Speed Mower A.K.A. PA's Redneck Roadster
» Slingshot roadster
Motohorseman :: Central Missouri Motorcycle Riders :: Rumblings-
