UPDATED THROUGH JULY 2012 08/11/12 sbHere is a list of the items I've sold over the past few months and the prices they brought.
I do this to give you an idea of what a part is now worth, or at least what someone paid for it.
These are Kawasaki parts, "NOS" unless otherwise stated.
Sorted by highest to lowest
Title and then the amount the item sold for H2 750 Cylinder Cylinders Left Center Right Full Set Original Boxes $1,825.00
- 11005-111 Cylinder Right (Hand written note: 11005-087 )
- 11005-110 Cylinder Center (Hand written note: and 11005-086 )
- 11005-085 Cylinder Left Hand (Hand written note: 11005-085 goes to 11005-109 )
13254-001 Close Ratio Gear Set Z1R KZ900 KZ1000 Z1-R Kawasaki $1,500.00
11005-136 Z1 Cylinder Block Z-1 900 1973-75 Sti $1,479.73
13254-001 Close Ratio Gear Set Z1R KZ900 KZ1000 Z1-R Kawasaki $1,151.00
53001-1015 Dual Seat Assembly Z1R Z1-R KZ1000 ( $885.00
21119-006 Ignition Unit A Mach III H1 500 $725.00
13064-006 Kick Start Lever Pedal H2 750 Mach IV Tr $640.00
Cylinder Standard Bore KX125 1974 - 1979 Electrofusion Bore $519.99
51001-1011-8G Ebony Fuel Tank KZ1000 Mark II KZ1000-A Kawasa $515.00
13095-003 Clutch Hub Housing W1 W2 W1SS W2SS W2TT $434.00
46091-009 Left Hand Switch Case Assembly Z1 Z-1 90 $420.00
25005-028 Speedometer W1 W2 W1SS W2SS W2TT 650 Com $406.00
51001-089-2Y (?) Fuel Tank 400 S3 S3A Candy Green 1 $395.09
51001-107-3M KZ900 Diamond Green Fuel Tank 1976 KZ9 $394.75
45005-041 Lower Left Outer Fork Tube H1 H2 Mach $390.00
41080-005 Front Brake Rotor Disc KH500 KZ650 KZ750 $366.50
13031-3011 Jet Ski Crankshaft Assembly 440 550 $365.00
27003-014 Horn W1 W2 Commander 650 SS Early H1 Mach III 500 $365.00
32097-008 Battery Bracket or Box 1969 W2TT W2 TT 6 $365.00
Right Hand Cylinder Standard Bore S2 350 Mach II Triple NIB $341.00
25015-003 Tachometer W1 W2 W1SS W2SS W2TT 650 Commander $341.00
14026-026 Engine Cover Front Chain 1973-77 Z1 Z-1 $338.00
21007-029 Charging System Rotor Z1 900 DOHC 1973-75 $338.00
26001-095 Main Wiring Harness H1 500 Mach III 1973 $336.00
26001-026 Main Wiring Harness Commander W1 W2 650 SS TT Kawa $327.00
53001-1358 Dual Seat Assembly KZ1300 1979-1982 Minor Ble $327.00
11005-1476 Cylinder Standard Bore 1986 $325.00
25015-003 Tachometer W1 W2 W1SS W2SS W2TT 650 Comm $325.00
53001-1026 Dual Seat Assembly KZ1000 Shaft Drive 1979 1980 N $320.55
11005-056-21 Cylinder Std Bore Big Horn F5 F9 Black $320.00
25016-014 Tachometer H1 1972 H1B Kawasaki 500 Mach III Tripl $310.65
46017-020 Grip Assembly A1 A7 Samurai Avenger $308.00
41074-006 Front Wheel Assy H1 A&C Hub Spokes Rim NO $306.58
Blue Left Side Cover H1 Mach III 500 KH500 p/n 36001-034-58 $306.55
Left Hand Cylinder Standard Bore S2 350 Mac $305.00
16001-135 Carburetor H1 H2 ? Stamped KA4 $299.99
51001-0085-723 ZX-6R Candy Plasma Blue Fuel Tank 2 $299.93
44013-1003 Inner Fork Tube Set of 2 KZ1000 Z1R LTD $294.00
23040-009 23044-007 Turn Signal Left Side Roadrunn $292.00
43016-001 Master Cylinder Body Z1 Z-1 H1 900 500 Mach III $291.00
Cylinder Standard Bore Big Horn F5 F9 Black Natural Finish $290.33
Center Cylinder Standard Bore S2 350 Mach I $285.00
51051-004 Fuel Tank Gas Cap Early S2 H1 H2 350 500 750 Triple $283.00
53043-004-2S Candy Super Blue Rear Fender Cover Tail Cowl Z1 $275.65
44013-1003 Inner Fork Tube Set of 2 Kawasaki KZ100 $275.00
13064-016 Kickstart Lever H1 Mach III 500 Avenger SS Samurai $263.75
35004-048-70 Lime Green Front Fender F5 F9 Big Horn Bison Ka $261.56
42006-053 Rear Brake Panel Assembly w/ Shoes Z1 90 $259.93
13095-018 Clutch Housing aka Basket Mach III H1 $255.00
16001-166 Carburetor Right Carb H1 500 Ma $255.00
13029-1021 + 13025-5014 Piston and Ring .020 Over Size KZ750 $254.74
41080-005 Front Brake Rotor Disc KH500 KZ650 KZ750 KZ900 KZ1000 $249.97
35004-060-67 Front Fender 1972 Kawasaki H1B 500 Triple $246.50
35022-046-70 Lime Green Rear Fender F5 F9 Big Horn $234.50
21119-1074 CDI Ignitor KXT250 Tecate 250 NOS Kawasaki 1984 1 $233.95
36014-042 Chain Guard Cover Chrome Mach III H1 1969-72 Kawas $232.50
25015-023 Tachometer S1 S2 S3 KH250 KH400 Kawasaki NOS 250 3 $228.95
53043-008-2B Seat Cover Back Rest Tail Cowl S3 Mach II Candy Sky Blue $228.50
14025-5104-7F Rear Tail Cowl Seat Cover 1982-83 KZ1 $224.50
35022-046-70 Lime Green Rear Fender F5 F9 Big Horn Bison Kaw $224.50
16001-166 Carb Carburetor Right Hand H1 500 Mach III H-1 Kaw $220.50
18049-071 Header Exhaust Pipe H2 750 Triple Set $217.50
46018-018 Throttle Grip Assembly Kawasaki 500 750 Triple H1 $207.50
16082-040 Oil Pump Assembly 500 Mach III H1 Ser $202.74
23024-026-21 Tail Lamp Brake Light H2 1974-75 Mach IV 750 Tr $202.50
13066-028 Kick Start Shaft H2 750 Mach IV 1972 1973 H2A H2-A $202.50
41073-1016 Rear Wheel Assembly KZ1000 LTD NOS Kawasaki Mag 1 $199.99
16001-165 Carburetor Left or Center Carb H1 500 Mach III Triple K $199.99
21119-012 Ignition Unit A H2 750 Triple $199.99
51001-5120-8G Ebony KZ440 ltd Fuel Tank NOS Kawasaki 1981 19 $199.95
Right Hand Engine Cover for Mach III 500 Triple H1 KH500 $199.95
14031-1020 Engine Cover Left Side Z1 Z-1 900 KZ900 1973 - 19 $189.95
41080-001 Front Brake Rotor Disc H1 500 H2 750 Z1 $189.93
26001-065 Wiring Harness H1 H1B 500 Triple $187.50
35022-045 Stainless Steel Rear Fender Kawasaki Early H1 H-1 $182.50
27004-5020 Lock Set Ignition Key KZ650 Custom SR LT $172.50
13239-007 Shift Drum H1 500 H2 750 Mach III IV Triple All Years K $170.99
18057-040 Black Muffler Heat Shield 2'em A1SS A7SS Samurai $170.49
25015-002 Tachometer A1 Samurai 250 A7 Avenger 350 $167.50
35022-045 Stainless Steel Rear Fender Kawasaki Early H1 H-2 $162.59
11012-009 Air Cleaner Cap Right Side Commander 650 $162.50
11012-010 Air Cleaner Cap Left Side Commander 650 $162.50
11005-061-21 Cylinder Trail Boss G4TR K $159.95
13081-036 MT1 MT-1 KV74 KV-75 Mini Trail Clutch Ass $159.95
25016-025 Tachometer Assembly F11 250 Enduro 1973 $159.90
23007-013 Headlight Headlamp Lens W1 W2 Commander H1 Mach II $158.50
43045-001 Front Brake Caliper Allen Head Bolt Shaft 3'em H1 H2 $157.50
16082-013 Oil Pump Avenger Samurai A1 A7 250 350 S $156.75
13127-042 Shaft - Drive 12 T Z1 900 DOHC KZ900 KZ1000 1973-1981 $155.99
26001-059 Main Electrical Wiring Harness Kawasaki S2 Mach II $154.50
99996-3007 Carb Carburetor Jet Ski 550 JS550 Kawasaki NOS Mi $154.50
23025-041 Tail Lamp Light Assembly H1 H1B/C H2 H2A 500 750 K $152.50
35004-055-71 Front Fender Orange 1972 F6 A F6-A Kawasaki 125 $152.50
46091-001 Left Handlebar Turn Choke Switch Assembly H1 H1A H $152.50
500 Mach III Red Right Side Cover H1 H1E $150.90
53001-067 Dual Seat Assembly G3 G3SS G3TR Bushmaster Kawasak $150.38
46101-008 Steering Damper Knob 1973 H2 $150.10
21066-1002 Voltage Regulator KL250 $149.99
11005-1071 Cylinder KDX80 1980-81 $149.95
35022-045 Stainless Steel Rear Fender Kawasaki Ear $149.95
56013-003 56014-003 Fuel Tank Badge Set L&R Badges $144.50
500 Mach III Lime Green Right Side Cover H1 H1D $142.50
27003-027 Horn S2 Mach II 1972 1973 350 Triple S2A $142.49
33034-009 Swing Arm Bushing Sleeve Set Z1 900 H1 5 $140.00
41035-013 Front Brake Panel A1 A7 $139.99
13036-028 Crankshaft Assembly F6 125 Enduro $139.99
46091-001 Sealed Left Handlebar Turn Switch Assembly H1 H1A $139.95
13025-046 Piston Ring 0.05mm 4 Sets Z1 900 DOHC Z-1 KZ900 & LTD $139.50
43044-001 Front Disc Brake Caliper Holder H1 500 H $138.50
44039-025 Steering Stem Head Triple Clamp Top 1969 H1 500 Ma $138.29
14025-5038-B1 Rear Tail Cowl Seat Cover 1981 GPz550 Red KZ55 $135.95
46101-004 Steering Damper Knob H1 1969 500 Mach III 1972 H1- $135.83
Left or Right Hand Cylinder Head H1 Mach III 500 KH500 $135.83
13127-033 Transmission Input / Drive Shaft H2 750 Mach IV Triple $135.50
36014-046-21 Chain Guard Flat Black H1D 500 Mach III H1 $135.00
Bolt Bolts Rod Shift Kick Start Triple H1 H2 500 750 Z1 More! $135.00
53003-001 Seat Cover Dual Seat A1 A7 A1SS A7SS Ave $134.50
43051-01 Front Brake Pad B H1 H2 500 750 Triple Mach III IV $133.80
35022-055 Rear Fender H2 750 Triple Kawasaki Mach IV NOS Bla $132.50
35022-060-67 Rear Fender 1972 Kawasaki H1B 500 Triple $132.50
13087-027 Outer Clutch Hub H2 750 Mach IV Kawasaki $132.50
43026-003 Master Cylinder Oil Cup Cap Z1 H1 500 H2 $132.50
92123-002 Clamp Carburetor to Air Box Z1 900 Z-1 Z $132.00
14032-121 Clutch Cover Z1 Z-1 900 KZ900 KZ1000 $131.50
11001-1190 Cylinder Head KX125 125 Motocross MX 19 $130.88
34024-060 Kickstand Kick Side Stand Z1 Z-1 KZ900 Early KZ100 $130.27
44039-041 Steering Head Stem Triple Clamp 1972-75 G5 NOS Kaw $130.00
99996-3006 Carb Carburetor Jet Ski 440 JS440 Kawasaki NOS Mi $129.99
11005-052 Right Cylinder 500 H1 Mach III KH500 Vintage Kawa $129.95
11005-089-21 NOS Kawasaki Cylinder Standard Bore F11 250 End $129.95
11005-1137 Kawasaki Cylinder Standard Bore 1982 1983 KDX80 K $129.95
21119-012 Ignition Unit A H2 750 Triple Kawasaki Mach IV NOS $129.95
52001-015-58 Oil Tank Candy Blue H1 1970 H1A 500 Mach III Ka $129.95
43015-1046 Front Brake Master Cylinder KZ1000 LTD CSR Police $129.50
13140-013 Shift Fork Top Gear H1 500 Mach III A1 A7 All Years $129.00
46091-1214 Control Housing Switch Right GPz750 Turbo KZ1000-R1 $128.76
36001-1296 Air Filter Side Cover Chrome 900 1000 E $128.06
14032-1018 Engine Cover Right Hand S1 S2 Mach I $127.50
Left Cylinder Standard Bore Avenger SS A1 A $127.50
Right Cylinder Standard Bore Avenger SS A1 A1SS A1-SS 250 $127.50
27005-068 Ignition Switch with Keys Big Horn 350 125 175 F6 $126.50
Air Filter / Cleaner Rubber Duct Tecate 250 KXT250 1986 1987 $125.55
11001-066 Left or Right Hand Cylinder Head H2 Mach VI 750 Tr $123.45
41025-058 Rear Rim Takasago 215BX18 2L 305 H1 500 Mach III $122.50
13066-028 Kick Start Shaft H2 750 Mach IV 1972 1973 H2A H2-A $121.50
21061-008 Rectifier Early H1 H1A 500 Mach III Kawasaki NOS $119.99
18033-056 Baffle Tube 750 H2 Mach IV Triple $119.50
13088-011 Clutch Plate Plates Friction W1 W2 SS TT $117.50
13127-033 Transmission Input / Drive Shaft H2 750 Mach IV Triple $116.26
Decal Emblem Side Cover W2-SS W2 SS W650 1967 $115.50
13223-002 3 Tachometer Gears W1 W1SS W2 W2SS W2TT $115.50
11012-010 Air Cleaner Cap Left Side Commander 650 $113.50
23024-067 Tail Lamp Light Assembly KZ900 KZ1000 $113.40
42041-036 Rear Sprocket 42 Tooth Kawasaki W1 W2 Commander SS $109.50
52003-005 Oil Dip Stick Dipstick Cap Commander W1 W2 650 SS $108.50
16037-003 Carburetor Rubber Cap 5 each W2SS W2TT C $108.50
44039-025 Steering Head Triple Tree Clamp 500 Mach $106.73
25015-002 Tach Tachometer Avenger Samurai A1 A7 A1SS A7SS Ka $106.66
35004-061-68 Front Fender Pearl Candy Red 1972 1973 Kawasaki $106.66
13137-019 Top 5th Gear Output H2 750 Mach IV All Years Kawasaki N $106.00
18057-040 Black Muffler Cover Heat Shield A1SS A7SS Samurai + $106.00
13127-019 Drive or Input Shaft H1 500 Mach III Triple All Years K $105.99
Huge Grommet Assortment 500 750 H1 H2 Mach III IV and more $105.79
13140-013 Shift Fork Top Gear H1 500 Mach III A1 A $105.50
21018-001 Breaker Plate Assembly Kawasaki 500 Mach III H1B H $104.09
16001-142 Carburetor Carb G5 100 Enduro Dual Sport 1972 1973 $103.50
42041-108 Rear Sprocket 45 Tooth 750 H2 Mach IV H-2 Triple K $103.50
Right Hand Side Cover Ebony KZ1000 Z1R 1978 1980 $103.50
58029-1003-6W Front Number Plate KX250 KX420 Kawas $103.50
92075-033 Fuel Tank Bolt Damper W1 W1SS W2 W2SS W2 $103.50
27010-006 Rear Brake Light Switch W1 W2 SS TT Commander H1 500 $102.83
14025-5241-T3 Red & Black Seat Cover Rear Cowl Kawasaki ZX10 $102.51
21018-001 Breaker Plate Assembly 500 Mach III H1B H $102.50
27003-007 Horn in Original Box Samurai Avenger A1 A7 SS $102.50
43001-025 Rear Brake Pedal A1 Avenger A7 Samurai 1 $102.50
43001-060 Rear Brake Pedal Kawasaki S1 2 3 KH250 KH400 $102.50
44007-010 Outer Fork Tube Nut A1 A7 SS Avenger Sam $102.50
13095-032 Clutch Hub 250 S1 350 S2 Triple Mach I II 1972-76 $102.00
13128-020 Output Shaft H1 H2 500 750 Triple Mach I $102.00
23005-018-10 Headlight Shell W1 W2 A7 H1 500 Mach III Other $101.00
23040/43/43/44-02&03 Turn Signal Winker Blinker Se $100.99
13135-015 4th Gear Output H2 Mach IV 750 Triple Ka $100.00
13132-025 3rd Gear Drive H2 750 $100.00
27005-076 Ignition Switch Assembly Z1 900 Z-1 1973-75 Key # 762 K $99.99
21007-028 Generator Rotor NOS Kawasaki 500 Mach III H1 Serie $99.95
21120-006 Ignition Unit B Kawasaki 500 Mach III H1 D 1973 NO $99.95
35022-047 SS Rear Fender Kawasaki G4 G4TR 100 Enduro Trail B $99.95
44006-056 Right Lower Outer Fork Tube Kawasaki KZ400 1974-77 $99.95
27014-008 Hazard Light Switch KZ900 $99.93
42008-013 Rear Hub Coupling Assembly Z1 900 Z-1 KZ900 More $96.99
13064-004 Kickstart Lever Pedal Assembly W1 W2 $96.00
41048-016 Brake Shoe (2) Rear H2 750 Mach IV Z1 Z- $95.49
18057-014 Muffler Exhaust Cover Rear Avenger Samur $94.01
33034-005 Pivot Shaft Sleeve Swingarm Bushing W1 W $93.00
13090-008 Outer Metal Clutch Plate Plates W1 W2 Kawasaki NOS $92.00
Decal Emblem Side Cover W1 W2 SS W650 1967 $92.00
13024-049 Piston Ring Set 2 sets 0.040 1.00mm H2 7 $91.00
13034-010 Needle Bearing Big End 1 Each H1 500 Mac $90.00
13036-028 Kawasaki Engine Crankshaft Assembly F6 125 Enduro $89.95
16001-184 Carburetor Assembly Kawasaki NOS MC1 MC-1 KD80 $89.95
23003-015 Lamp Assembly Headlight F7 F9 A11 175 250 350 Endu $89.95
44039-040 NOS Steering Head Triple Tree Clamp Kawasaki 500 M $89.95
44039-048 NOS Steering Triple Tree Clamp Kawasaki 500 750 Ma $89.95
11005-064 Cylinder F6 125 Standard Bore $89.95
14003-060 Kawasaki NOS Right Side Crankcase Big Ho $89.93
27003-012 Horn A1 1966 Samurai 250 1968-70 F3 Bushwacker NOS $89.00
35004-055-73 Front Fender Red Kawasaki 175 Enduro F7 1972 NO $89.00
14031-1023 Engine Generator Cover KZ400 KZ440 Belt or Chain $88.05
13089-007 Steel Clutch Plate 5 Avenger 250 A1 Samu $87.00
35022-104 Rear Fender KX250 Motocross 1974 1975 1976 Kawasak $86.99
13044-5048 KX500 Connecting Rod Kit 1985-1987 $86.00
27016-014 Steering Lock Assembly with Key #524 3 Keys Kawasa $86.00
23005-032-10 Healight Body S2 350 Mach II $86.00
21018-001 Breaker Plate Assembly Kawasaki 500 Mach III H1B H $83.00
16009-017 Needle Jet 5L1 4 each W1 W1SS W2 W2SS W2 $82.00
13158-011 Gear Shift Change Lever H1 H2 500 750 Triple $82.00
13140-037 Shift Fork Top Gear S1 S2 S3 250 350 400 All Years Kawa $81.99
13089-007 Steel Clutch Plate 5 Avenger 250 A1 Samurai 350 A7 $81.00
46074-040 Left Grip Hand Switch Case W1 650 W1S $80.99
46082-014 Wiring Harness Switch Gear H1 500 Mach III Triple $80.66
14025-1243 Right Hand Engine Cover KZ1000 Kawasaki $79.99
Cylinder Head Avenger Samurai A1 A7 A1SS A7SS 1967-71 $79.95
14032-1031 KZ750 Engine Side Cover Kawasaki NOS LTD II CSR Models $79.95
52001-023 Oil Tank MT1 MT-1 Mini Trail 1971-75 Gre $79.00
13061-007 Kick Start Lever Boss H1 Mach III 500 H1 $78.73
36001-018-24 Side Cover Left Candy Red Avenger Samurai A1 A7 $78.55
14032-121 Clutch Cover Z1 Z-1 900 KZ900 KZ1000 Kawasaki NOS $78.00
27008-042-89 The Key #689 689 H1B H2A S2 350 500 750 Triple $78.00
13089-010 Metal Clutch Plate Plates W1 W2 Kawasaki NOS W1SS $77.00
23005-018-21 Headlight Bucket H1 500 Mach III W1 W2 A7 Othe $77.00
13140-048 Shift Fork Top Gear H2 750 Mach IV All Years Kawasaki N $76.66
14032-061 Engine Cover Right Hand S1 S2 Mach I $76.38
23016-002 High Beam Indicator Light Assembly W1 W2 $76.00
14032-058 NOS SEALED Kawasaki Engine Cover Right Hand MT1 MT $73.99
56019-008 Oil Tank Cap W1 W1SS W2SS Commander W2TT $72.91
33043-005 Chain Adjuster Rear Axle Set (two) Z1 90 $72.88
92037-034 Clamp Carburetor to Air Box Filter H1 50 $71.99
14032-082 Clutch Cover Z1 Z-1 900 KZ900 KZ1000 Kawasaki NOS $71.00
33001-040 Swingarm Kawasaki H1 Mach III NOS Triple 1969-1972 $71.00
23048-004 3 Turn Signal Winker Blinker Lens A1 W1 $71.00
92037-035 Air Cleaner Filter Clamp H1 Mach III 500 $71.00
Engine Cover Cap Left Side 5 ea W1 W2 W2SS W2TT Co $71.00
32109-009 Frame Grip Grab Bar H1 500 Mach III Early $70.99
13095-053 Clutch Hub Basket Kawasaki F6 F7 175 Enduro KE175 $69.99
13127-019 Shaft Drive H1 H-1 500 Mach III Triple Kawasaki NO $69.99
13081-030 MB1 MB-1 Mini Bike Coyote Clutch Assembl $69.99
21121-054 Coil Right and Left Side H1 H1B H1-B 500 $69.99
13158-011 Gear Shift Change Lever H1 H2 500 KH500 750 Triple $69.99
16082-029 OilPump F7 175 Enduro Dual Sport $69.99
13090-008 Outer Metal Clutch Plate Plates W1 W2 Kawasaki NOS $69.95
14030-036-80 Oil Pump Cover H1 Mach III 500 1972-19 $69.95
14032-106-80 Kawasaki KZ400 Right Hand Engine Side Cover NOS $69.95
21077-002 Field Coil KZ400 Kawasaki NOS 1974-1977;Relisting $69.95
23007-025 Sealed Beam W1 W2 Commander H1 500 Avenger Samurai $69.95
25015-019 Tach Tachometer 125 175 Enduro F6 F7 $69.95
13081-056 Clutch Assembly KD80 KD100 KE100 G3 G4 SS TR MC1 $69.93
43001-047 Rear Brake Pedal H1 500 Mach III Triple 1 $69.88
21061-014 Rectifier H1 H1D H1-D 500 H2 750 Triple $69.00
13001-050 Piston Standard H2 750 Mach IV Kawasaki $67.00
13133-024 3rd Gear Output H2 750 Triple $67.00
44033-071 Left Hand Fork Cover Headlight Bracket Z $66.99
14026-022-80 Engine Chain Cover S1 S2 S3 250 350 400 Tri $66.56
13089-019 Clutch Plate Metal Set of 7 H2 750 Mach $66.09
14026-012 Engine Cover Oil Pump Z1 Z-1 900 KZ900 KZ1000 Z1R $66.00
13156-026 Gear Shift Lever H1 500 Triple All $65.99
13064-004 Kickstart Lever Pedal Assembly W1 W2 $64.25
13027-049 Piston 0.040 1.00 Oversize H2 750 Mach I $64.00
92060-001 Banjo Bolt Oil Tank Kawasaki H1 500 Mach $64.00
Right Hand Side Cover Red 1981 KZ550 KZ550-D1 GPZ550 GPz $63.93
Silver Left Hand Sidecover Side Cover Avenger Samurai $63.89
53045-001 Seat Hook Latch Assembly H2 750 Mach IV $63.66
Left Hand Side Cover Ebony 1982 1983 KZ750 Spectre $63.00
250 Mach I Gold Right Side Cover S1 KH250 $62.00
51001-1009-7W Used Fuel Tank KZ1000 Z1R Z1-R Kawasaki KZ1000 $61.01
13027-049 Piston 0.040 1.00 Oversize H2 750 Mach I $61.00
13087-030 Clutch Hub Mach III H1 500 Triple KH500 $61.00
51048-1002 or 51048-1008 Used Fuel Gas Cap Z1R KZ1000 D1 D3 $60.98
25001-045 MPH Speedometer Assembly Big Horn F5 $60.00
26001-056 Optional Wiring Harness F6 F7 $59.99
43001-1001 Rear Brake Pedal KZ1000 LTD 77-80 $59.99
92087-004 Tachometer Guide Commander 650 SS W1 W2 $59.99
13137-010 Top 5th Gear Output H1 500 Mach III All Years Kawasaki $59.99
13242-009 Gear Shift Lever S1 S2 S3 250 350 Mach I II Triple $59.99
18033-007 18033-014 Baffle Tubes I'm Baffled Avenger Samurai $59.95
52001-019-24 Oil Tank Candy Red G4TR Trail Boss 100 Enduro K $59.95
36001-5445 Right Hand Side Cover Ebony Ninja 900 84-85 $59.95
12049-1012 Cam Chain Adjuster Holder KZ650 KZ750 KZ1000 TC Z1R $59.95
14032-064 Right Hand Engine Cover 1971 F5 Big Horn 350 $59.95
25011-049 Speedometer Wiring Socket Holder KZ650 K $59.93
99996-1021 Cam Chain Tensioner Kit KZ650 KZ750 GPz750 Turbo $59.00
21135-011 Breaker Point Assembly Z1 900 KZ900 KZ1000 1973-81 $58.99
53044-004 Seat Molding Trim Piece Later Model H1 500 Triple $58.99
36001-5022-C4 Right Hand Side Cover KZ1000 ST Shaft Gray $58.90
Mahogany Ride Side Cover KZ1000 LTD 1978 ? $58.72
13002-022 Piston Pin Set of 4 Z1 900 DOHC KZ900 KZ1000 1973-81 $58.57
G3 G3SS SS Right Hand Side Cover White Bushmaster $58.00
23051-011 Turn Signal Bracket Optional 1969-71 H1 $58.00
13132-014 3rd Gear Drive H1 500 Mach III All Years Kawasaki NOS $57.99
26001-056 Wiring Harness Optional 125 175 Enduro F6 $57.35
53045-003 Seat Hook Assembly Keys 1973 H2 750 S1 2 $57.29
27005-070 Ignition Switch Assembly F11 250 Enduro 1973-75 $56.99
46074-036 Left Hand Grip Assembly F3 F2 Bushwhacker Sidewinder Ka $56.57
44041-021 Bolt Fork Top H1 500 Mach III Triple 1969-72 A PA $56.00
34024-065 Side Kick Stand KZ900 KZ1000 LTD 1976-80 $56.00
12046-001 Cam Sprocket Intake Z1 900 DOHC KZ900 KZ1000 1973-81 $56.00
12046-002 Cam Sprocket Exhaust Z1 900 DOHC KZ900 KZ1000 1973-81 $56.00
27008-042-88 The Key #688 688 2'em 1972 S2 350 H2 750 Triple $56.00
44022-027 Fork Cylinder H1 E/F H2 500 750 Mach III IV Triple ;Relisting i $56.00
46091-1186 Left Hand Control Housing Assembly KZ650 KZ1000 CSR $56.00
25015-011 Tachometer Assembly 175 Enduro F7 $55.95
92071-059 Grommet Rear or Tail Cowl H2 750 Triple Kawasaki NOS $55.29
44034-069 Right Hand Fork Cover Headlight Bracket $55.00
21160-005 Spark Plug Cap S3 350 Mach II KH400 Set of 3 Kawas $54.00
92060-006 Banjo Bolt for Carburetor W1 W2 W2SS W2T $54.00
36001-1011-A5 NOS Kawasaki Left Hand Side Cover Lu $53.99
Left Hand Side Cover Navy Blue KZ1000 1977-1980 $53.02
35022-135 Rear Fender KZ750 1976 1977 1978 1979 Kawasaki NOS $52.99
36001-039-91 Left Hand Side Cover Orange S1 S2 250 $52.91
13134-011 4th Gear Drive H2 750 $52.00
26001-012 Wiring Harness KA 302-7610 A 1966 ;Relisting item: 221062481342 $52.00
16051-002 Clamp Carb Mount H1 Avenger Samurai Mach III 500 $51.96
27005-1029 Ignition Switch KL250 KE250 $51.93
18048-014 Exhaust Muffler Tail Piece Avenger A1 Sa $51.60
25015-009 Tachometer Assembly NOS Kawasaki Big Horn Bison F5 $51.00
18057-011 Muffler Exhaust Cover Front F3 Bushwhack $51.00
23006-1003 Headlight Chrome Rim KZ1000 Z1R Z1-R + Turbo T/C $51.00
33032-038 Swingarm Pivot Shaft Swing Arm H1 H2 500 750 Triple $51.00
56014-003 Fuel Tank Badge Right Side Emblem 1960's J1 F1 $51.00
92072-018 Wiring Band Rubber Set of 10 Mach III Commander A1 A7 $51.00
13134-003 4th Gear Drive H1 500 Mach III A1 A7 All Years Kawasaki $50.99
51048-1003 Gas Cap Assembly KZ550 KZ650 KZ750 KZ1000 KZ1100 $50.99
23036-045 Tail Light License Plate Bracket 1979 KZ1000 Z1R Z $49.99
51001-074-67 Used Fuel Tank Pearl Candy Orange H1 B/C 500 Ma $49.99
12048-001 Cam Chain Tensioner Wheel Assembly Z1 KZ $49.99
16028-1001 Carburetor Throttle Diaphram KZ750 $49.99
23025-064 Tail Lamp Brake Light KZ1000 Z1R $49.99
23036-034-10 License Plate Frame $49.99
34024-065 Side Kick Stand KZ900 KZ1000 LTD 1976-80 $49.99
42041-036 Steel Rear Sprocket 42 Tooth Kawasaki NOS W1 W2 $49.99
52001-025 Oil Tank S2 S2A Mach II 350 Triple 1972 $49.99
92003-040 Shift Lever Joint Bolt Early H1 500 Mach $49.99
13135-007 4th Gear Output H1 500 Mach III All Years Kawasaki NOS; $49.99
13156-028 Right Hand Shift Lever Early H1 $49.99
13161-035 Gear Shift Shaft H1 Mach III 500 H2 750 IV Triple Kawas $49.99
25011-042 Indicator Light Electrical Socket Assembly Z1 900 Kawas $49.99
25012-023 Chrome Speedometer Cover KZ900 LTD $49.99
25012-024 Chrome Tachometer Cover KZ900 $49.99
34024-065 Side Kick Stand KZ900 KZ1000 LTD 1976-80 Cafe Custom $49.99
44034-042-21 Right Hand Fork Cover Black H1 Mach III 500 1972 Kaw $49.99
56001-1030 Mirror Right or Left Z1 900 Z-1 KZ900 KZ1000 More ? $49.99
92060-010-79 Banjo Bolt Oil Pump 3'em H1 500 H2 750 Mach III IV $49.99
Used 56002-021 Mirror Left and Right 1973-75 Z1 900 DOHC Mirrors $49.99
13084-005 Clutch Hub Set H1 500 Mach III F5 Big Horn F9 350 $49.95
13089-010 Metal Clutch Plate Plates W1 W2 Kawasaki NOS W1SS $49.95
14027-020-80 Engine Generator Cover Mach II Kawasaki NOS 350 $49.95
16137-002 Fuel Drain Pump Big Horn Kawasaki F5 F7 KD175 KE17 $49.95
33001-049 Swingarm H2 750 Triple Kawasaki Mach IV NOS H2A H2 $49.95
46017-077 Throttle Grip Assembly MT1 MT-1 KV75 Kawasaki NOS $49.95
14031-052 Inner Stator Cover 1972 S2 350 Left Hand Engine Silver $49.95
16085-011 Oil Pump Gear H1 500 H2 750 Mach III All Years IV $49.95
26001-050 Wiring Harness G3TR Bushmaster Bush Master 1969 1970 $49.93
12012-001 2 Valve Guide Guides W1 W1SS 650 Twin Ka $48.00
44033-41-21 Left Hand Fork Cover Black H2 Mach IV 750 1973 K $47.62
27008-042-87 The Key #687 687 S2 350 Mach II Triple $47.60
27008-042-89 The Key #689 689 2'em H1B H2 S2 350 500 750 Triple $47.09
26010-014 Battery Ground Wire 3 ea! Early H1 500 M $47.00
34024-016 Side Kick Stand H1 500 Mach III A1 Aveng $47.00
16006-021 Throttle Slide Valve Spring Set of 3 H2 750 Mach IV Kaw $47.00
21165-001 Start Motor Cover Chrome Z1 Z-1 900 KZ900 KZ1000 Z1R $46.99
44039-026 Steering Stem Upper Triple Tree A1 A7 Sa $46.93
36010-5065-6W Right Side Cover Lime Green KDX80 KD $46.88
K14046-110 Engine Gasket Kit S2 Mach II 350 Triple $46.57
59236-506 Fuel Filter Jet Ski 440 550 JS440 JS550 $46.55
34003-015 Rider Right Foot Rest Bar Early H1 500 M $46.49
52020-001 Oil Filter H1 500 H2 750 Triple Mach I II III IV More $46.29
16134-016 Oil Pipe Left Cylinder H2 H2A 1973 Mach IV 750 Tri $46.00
16009-055 Carburetor Adjustable Needle Jet Set of $46.00
56013-003 Fuel Tank Badge Left Side Emblem 1960's J1 F1 $46.00
36010-5064-6W Left Side Cover Green KDX80 KDX-80 K $45.48
46089-006 Left Hand Switch B 1972 S2 H1B 500 H2 H2 $45.44
27003-1016 Horn Right Hand KZ1300 1980 KZ1300-B2 Kawasaki NOS $44.99
14032-065 Kawasaki Engine Cover Right Hand F8 250 Enduro Bis $44.00
13223-001 Tachometer Gear W1 W1SS W2 W2SS W2TT 650 $44.00
54018-004 Tachometer Tach Cable W1 650 W1SA Kawasa $44.00
13158-007 Gear Change Lever S1 S2 S3 KH250 KH400 350 400 Triple $44.00
46056-001 Cable Adjuster Lock Nut 3'em H1 A1 A7 Mach III 500 $44.00
54022-005 A1 Samurai Rear Brake Cable A1SS $43.99
14026-005-80 Chain Case Sprocket Cover Big Horn Bison F5 F8 F9 $43.25
Decal Emblem Right Hand S2 350 Triple Orange 4 Each Mach II $43.18
Blue Left Side Cover Mach I II KH250 250 350 Triple S1 S2 $43.01
43059-001 Front Brake Hose Master Cylinder Side 19 $43.00
13140-053 Shift Fork Low Gear S1 S2 S3 250 350 400 All Years $42.99
13140-054 Shift Fork 2nd to 3rd S1 S2 S3 250 350 400 All Years Ka $42.99
16134-007 Oil Pipe Right Cylinder H1 500 Mach III $42.98
18033-052 Exhaust Muffler Baffle 1972 1973 F9 Big H $42.00
21121-053 Coil Right Side S1 S2 250 350 Triple KH2 $41.99
13133-015 3rd Gear Output H1 500 Mach III All Years Kawasaki NOS $41.99
27003-012 Horn A1 Samurai F3 Bushwhacker $41.57
35023-1025-6W Rear Febder Green KX80 KDX80 1979-81 $41.55
56018-164 Side Cover Panel Badge 2'em 400 S3 KH400 Triple $41.29
92037-036 Exhaust Clamp W1 W2 SS W1SS W2SS Command $40.00
41053-011 Front Brake Lever Cam @ Drum H1 W1 W2 Commander SS TT $40.00
14025-1416 Right Engine Pulser Gold Cover Spectre KZ1100 ? K $39.99
13095-025 Coyote Clutch Housing 1969 1970 MB1 MB1A $39.99
14025-1416 Right Engine Pulser Gold Cover Spectre $39.99
16134-015 Oil Pipe MT1 $39.99
18033-046 Exhaust Baffle Tip MT1 MT-1 Mini Trail 1 $39.99
23006-034 Headlight Rim S2 H1 500 Mach I III $39.99
44007-015 Outer Fork Tube Nut H1 Mach III 500 Trip $39.99
14025-1414 Right Engine Pulser Cover Spectre KZ1100 $39.99
14031-036 G4 G4TR TrailBoss Left hand Engine Cover Kawasaki NOS $39.99
21121074 Ignition Coil Late Model H1 500 mach III Triple KH500 Kawasaki NOS $39.99
13084-005 Clutch Hub Set H1 500 Mach III F5 Big Horn F9 351 $39.95
14025-5028 Transmission Cover KZ1000 Police 1000 Z1 $39.95
18049-074 Exhaust Pipe S2 350 Triple Kawasaki NOS S2 $39.95
36001-053-3Q NOS Vintage Kawasaki Left Hand Side Cover Coppe $39.95
36007-042-2L Side Cover Candy Super Blue KZ400 Right Hand Si $39.95
14032-090-21 Right Engine Cover Black F9 350 $39.95
36001-057-7Z 36001-5012-7Z Left Side Cover Blue KZ $39.93
16009-054 Needle Jet 3 each H2 750 Triple Mach IV Kawasaki NOS;Fi $39.00
23064-001 Head Light Lamp Bracket Bison Big Horn A PAIR BOTH $38.51
41035-031 Front Brake Panel with Shoes MT1 MT-1 KV75 KV-75 ;Relisting ite $38.41
44034-023-10 Right Fork Cover Black Early H1 Mach III 500 Ka $37.99
18044-007 Exhaust Pipe Holder Flange H1 H2 Mach III IV 500 750 $37.99
Decal Emblem Left Hand S1 S2 250 350 Triple ? Green 4 Each $37.00
46089-005 Left Hand Switch A 1972 S2 H1B 500 H2 H2 $37.00
27002-004 Flasher Turn Signal Relay W1 W2 Commander Samurai Avenger $37.00
44033-016-24 44034-015-24 Candy Red Fork Cover Left and Righ $36.99
A7020-5450 Starter Cable Metal Joint Cover 1960's $36.99
41027-043 Rear Spoke Assembly Inner Set of 10 H2 750 Triple ;Relisting it $36.98
36001-1029-6W Side Cover Green Left Side KX80 KX-8 $36.66
92072-018 Wiring Band Rubber Set of 10 Mach III Co $36.35
16134-018 Right Hand Oil Pipe 1973 H2 H2-A 750 Tri $36.29
43001-025 Optional Brake Pedal 32067-009 Bracket H1 500 Triple ;Relisting $36.09
16139-001 Oil Seal Ring 4 of 'em W1 W1SS W2 W2SS W $36.00
46132-020 Switch Gear Right Hand Side KZ400 Special 1975 KZ400S K $36.00
53054-001 Seat Hook Stopper 6'em Z1 Z-1 900 KZ550 GPz550 KZ1000 K $36.00
23026-004 Lens Tail Light 1966 JL1 JL-1 ? Kawasaki NOS $35.99
13001-025 Piston Standard STD W1 W2 650 Commander $35.99
14026-027-21 Sprocket Chain Case Cover Black F11 2 $35.99
A7020-5450 Starter Cable Plastic Joint Cover 1960' $35.99
14025-1280 Pulsing Coil Cover B KZ1100-B2 GPz1100 GPz 1100 K $35.95
13025-045 Piston Ring Set 0.020 0.50mm H2 750 Triple Kawasaki NOS $35.95
14025-1011 Speedometer Cover Police KZ1000P $35.95
44037-055 Steering Stem Lower Triple Tree F9 Big H $35.93
14032-062 Engine Cover Right Hand Side F6 125 $35.93
46032-014 Wiring Harness R Switch W1 W2 W2SS W2TT 650 Commander $35.00
14002-078 Crankcase Left SideF6 F7 $34.93
44034-016-14 Fork Cover Headlight Bracket 1968 196 $34.69
27002-004 Flasher Turn Signal Relay W1 W2 Commande $34.33
27002-004 Flasher Turn Signal Relay W1 W2 Commander Samurai $34.00
13157-003 Shift Rubber B 8 each W1 W2 W2SS W2TT Co $34.00
26010-015 Battery Lead Wire H1 500 Mach III Avenge $34.00
21143-002 Distributor Shaft Early H1 500 Mach III Triple ;Relisting item: $34.00
54012-045 A7 350 Avenger Throttle Cable $33.99
46092-012 H1 1969-1972 Clutch Lever 500 Mach III $33.98
51059-007 Cap Cap Gasket Seal Avenger Samurai H1 650 Commander Ka $33.33
27005-035 Ignition Switch w/ Key F6 F7 175 Enduro Dual Sport $33.00
92074-024 Rubber Case Plug Tool Box Tray Handle Z1 900 KZ1000 Kaw $33.00
14032-075-2H Kick Start Kickstart Engine Case Cove $32.99
32100-013 Battery Band Holder Down Early H1 Mach I $32.99
41048-007 Brake Shoe Front H1 500 Mach III W1 W2 6 $32.99
51023-1356 Fuel Tap Petcock KLF300 Bayoo 300 $32.99
27008-042-87 The Key #688 688 2'em S2 350 Mach II Triple $32.79
27008-027-69 The Key #669 669 Early H1 A/B/C 500 Mach III $32.59
16033-009 Float Chamber Screw 14 ea Z1 900 H2 750 H1 500 A7 A1 K $32.55
K14046-109 Engine Gasket Kit S1 Mach I 250 Triple $32.50
92037-043 Air Inlet Pipe Clamp 1969 Kawasaki H1 Ma $32.00
13156-039 Gear Shift Lever H2 750 Mach IV Triple All Years Kawasa $32.00
16134-007 Oil Pipe Right Cylinder H1 500 $32.00
18057-010 Lower Muffler Cover Heat Shield A1 A1SS Samurai 250 $32.00
41028-43 Front Outer Spoke 10'em H1 500 W1 W2 W2SS TT Commander $31.99
26009-001 Wiring Harness Cover W1 W2 W2SS W2TT 650 $31.20
16134-026 Oil Pipe Right Cylinder 750 Mach IV 750 $31.05
27003-021 Horn G3 Bushmaster TR SS $31.00
92001-041 Oil Pump Pinion Bolt W1 W1SS W2 W2SS W2T $31.00
27008-055-08 The Key #908 908 2'em S3 KH400 400 Triple $31.00
18064-004 Muffler Cover Heat Shield 1971 F81M Green Streak 250 $30.99
27008-027-76 The Key #676 676 Early H1 A/B/C 500 Mach III $30.10
27009-001 Ignition Switch Housing Avenger 250 A1 S $30.00
41042-009 Front Disc Brake Hub Dust Cover H1 500 H $30.00
K14046-111 Engine Gasket Kit 1974 1975 S3 400 Trip $30.00
13034-010 Bearings (Sold on PayPal 725201213034010) $30.00
13093-002 Clutch Return Rubber Short 40 of 'em Ave $29.99
21142-003 Ignition Distributor Rotor H1 Mach III 5 $29.99
27003-063 Horn G4TR G4 TR Trail Boss 1970-73 6V 1. $29.99
13087-033 Clutch Hub S1 S2 250 350 Mach I II KH250 $29.99
13151-021 Neutral Switch S1 S2 S3 KH250 KH400 Triple Mach III $29.99
14025-1099 Muffler Cover Left Side 1977-80 KZ650 incl Custom $29.99
14025-1100 Muffler Cover Right Side 1977-80 KZ650 incl Custom $29.99
92037-179 Exhaust Muffler Clamp Set 4 KZ650 1977-80 Kawasaki NOS $29.99
25008-009 Meter Bracket A1 A7 H1 Samurai Avenger Mach III 500 ;Relisting $29.97
13136-041 Top 5th Gear Drive H1 500 Mach III All Years $29.96
14032-060-21 Kawasaki Engine Cover Right Hand Black F7 175 E $29.95
27005-059 Ignition Switch Assembly with Keys KE125 KS125 End $29.95
36001-1011-A5 NOS Kawasaki Right Hand Side Cover Luminous Bu $29.95
16061-012 Carb Heat Insulator Set of 3 350 400 Mach I II Triple $29.95
18033-086 Exhaust Muffler Baffle Tube KS125 KE125 KD126 $29.95
23036-020-21 License Plate Bracket H1 500 KH500 Tr $29.93
16134-024 Oil Pipe Left Cylinder 750 Mach IV 750 Triple Kawasaki $28.99
16134-025 Oil Pipe Center Cylinder 750 Mach IV 750 Triple Kawasak $28.99
53011-001 Dual Seat Pin H1 500 Mach III Avenger Samurai BigHorn K $28.99
A7020-5450 Starter Cable Metal Joint Cover 1960's Kawasaki NOS $28.05
46075-005 Left Hand Grip W1 W2 SS TT Commander Ave $27.69
26002-063 Rear Wiring Harness KZ550 KZ650 KZ750 CSR LTD Spectre $27.53
54012-058 A1 Samurai Combination Cable Low Bar Vers $27.45
13130-017 2nd Gear Drive H1 500 Mach III All Years $27.09
41053-011 Front Brake Lever Cam @Drum H1 W1 W2 Com $27.00
23044-002 Turn Signal Winker Blinker Left Rear Vintage $27.00
1983 1984 1985 XL600R XL600 Honda Service Manual Pre-Owned Part # 61MG202 $26.99
18057-032 Muffler Exhaust Cover Front Bushmaster G $26.99
14019-021 Rotary Disc Valve Cover Right A1 Samurai A7 Avenger $26.95
46075-005 Left Hand Grip W1 W2 SS TT Commander Avenger Samurai $26.57
13058-039 Kick Start Lever J1 D1 G1 C1 C2 Roadrunner $26.55
41035-021 Coyote Front Brake Panel 1969 1970 MB1 M $26.50
46094-011-21 Clutch Lever Bracket Z1 900 H2 750 Mach IV H1 500 Ka $26.01
1985 CMX250C CMX250 CMX 250 Rebel Honda Service Manual Pre-Owned Part # 61KR300 $26.00
26002-020 Wiring Harness Headlight Commander 650 SS TT W1 W2 $26.00
13157-002 Gear Toe Shift Rubber 3 Each W1 W2 SS TT $26.00
46094-019 Clutch Lever Holder KZ1000 Z1R Z1-R TC P $26.00
51044-029 Fuel Pipe Tank to Carburetor W1 W2 SS TT $26.00
92001-025 Fuel Tank Bolt W1 W1SS W2 W2SS W2TT Comm $26.00
27008-055-03 The Key #903 903 S3 KH400 400 Triple ;Relisting item: 221066 $26.00
42014-021 Rear Hub Damper 2'em Z1 900 Z-1 KZ900 DOHC 1973-77 $26.00
52019-001 Chain Oiler Cap Gasket Set of 4 H2 750 Triple Mach IV $26.00
92037-035 Air Cleaner Filter Clamp H1 Mach III 500 Triple KH500 K $26.00
27003-055 Horn G3 Bushmster TR SS $25.49
92037-036 Muffler Exhaust Clamp 39mm ID Kawasaki NOS $25.39
16014-007 Pilot Air Screw Screws 5 each W2SS W2TT $25.00
16067-005 Carburetor Cap Bolt Set of 4 1973 1974 1 $25.00
27008-055-04 The Key #904 904 S3 KH400 400 Triple ;Relisting item: 320940 $25.00
14025-1671 Cover Pulsing Coil GPz1100 ZX1100 1983-84 Kawasak $24.99
18049-023 Exhaust Pipe Vintage Kawasaki F1 175 1960's NOS $24.99
23005-1006-21 Headlamp Headlight Body Bucket MT1 KV75 Others $24.99
44033-054-21 Left Hand Fork Cover Black S1 Mach I 250 Kawasa $24.99
46022-012 Switch Case Right Hand Lower Commander W2 W2SS W2T $24.99
54017-051 Starter Cable Kawasaki NOS 250 350 Triple S1 S2 KH $24.99
12049-1003 Cam Chain Adjuster Holder Z1 900 KZ650 $24.99
13187-005 Clutch Spring Plate Mach III H1 500 H2 7 $24.99
14015-001 Crankcase Oil Receiver A1 A7 S1 S2 S3 H1 $24.99
192076-010 Rubber Footrest 2 W1 W2 W1SS W2SS W2TT $24.99
26001-012 Wiring Harness KA 302-7610 A 1966 Kawasa $24.99
32098-013 Tool Box F6 F7 125 175 Enduro Dual Sport $24.99
34028-1008 Footrest Foot Rest Peg Front Right KZ65 $24.99
42041-036 TAB LOC Rear Sprocket 42 Tooth Kawasaki $24.99
42041-138 Rear Sprocket 41 Tooth S3 350 $24.99
44022-009 Fork Damper Rod Cylinder Set Big Horn Bison $24.99
44033-016-24 44034-015-24 Candy Red Fork Cover Lef $24.99
46017-014 Brake Lever Assembly Right Hand Front 19 $24.99
46019-013 Throttle Grip Assembly Big Horn F5 F6 F7 $24.99
54022-021 Kawasaki Rear Brake Cable S1 S2 KH250 25 $24.99
92043-053 Brake Rod Pin W1 W2 650 Commander H1 A1 $24.99
K14046-103 Engine Gasket Kit 1973 F11 250 Kawasaki $24.99
K14046-115 Engine Gasket Kit KX250 Kawasaki NOS $24.99
Points and Condensers 2 sets MB1 MB-1 Mini Bike Co $24.99
13151-018 Neutral Switch Z1 Z-1 900 DOHC F11 250 F11M $24.99
16021-018 Throttle Stop Screw Set of 3 Z1 900 Z-1 DOHC $24.99
16134-014 Oil Ipe Right Cylinder 250 350 400 Mach I II Triple Kawasaki NOS $24.99
18064-005 Black Muffler Cover Heat Shield F6 F7 125 175 Enduro $24.99
23051-018 Turn Signal Bracket Right Rear 1972 H1B H1C 500 H1 $24.99
23051-019 Rear Left Blinker Turn Signal Bracket H1 500 Mach III $24.99
23076-001 Headlight Turn Signal Collar Ground Wire Z1 900 H1 H2 K $24.99
26001-4011 Main Electrical Wiring Harness Duckster KLT200 Kawasaki NOS $24.99
27002-004 Flasher Turn Signal Relay W1 W2 Commander Samurai Avenger $24.99
34003-015 Rider Right Foot Rest Bar Early H1 500 Mach III $24.99
41027-042 Spoke Assembly Inner 9'em H1 H2 500 750 Triple Z1 900 $24.99
55011-010 Skid Plate Engine Guard G4 G4TR Trail Boss KV100 100 $24.99
92037-035 Air Cleaner Filter Clamp H1 Mach III 500 Triple KH500 $24.99
92081-095 Clutch Spring 5'em S2 S3 350 400 Mach II KH400 Triple $24.99
54005-061 Brake Cable Front S1 S2 250 1972 350 Triple Mach I II ;Relistin $24.97
42031-045 Rear Axle No Hole H2 B/C Mach IV 750 Triple Kawasa $24.95
42031-045 Rear Axle with Hole H2 B/C Mach IV 750 Triple Kawa $24.95
14019-020 Rotary Disc Valve Cover Left A1 Samurai A7 Avenger $24.95
25008-009 Meter Bracket A1 A7 H1 Samurai Avenger Mach III 500 $24.95
14030-031 Carburetor Cover 1971 F81M Green Streak $24.93
23051-019 Rear Left Blinker Turn Signal Bracket H1 500 Mach III K $24.93
54017-051 Starter Cable 250 350 Triple KH250 $24.93
42006-018 Rear Brake Panel 125 175 Enduro F6 F7 1971-75 $24.91
13061-019 Kick Lever Pedal Boss KX250 1974 1975 19 $24.50
1983 1984 XL600R XL600 Honda Service Manual Pre-Owned Part # 61MG201 $24.49
32132-003 Spark Plug Cover S1 S3 H1 500 H2 750 Mach I II IV $24.00
33040-032 Chain Adjuster Left Side A1 A7 Avenger S $23.50
92071-031 Ignition Distributor Grommet 3'em 500 H1 Mach III $23.50
18048-005 Exhaust Tail Pipe Tip Chrome Samurai Avenger $23.27
27008-027-69 The Key #669 669 Early H1 A/B/C 500 Mach III $23.05
18069-038 Exhaust Pipe Holder Flange S1 S2 Mach I II 250 350 ;Relisting i $22.97
21088-014 Carbon Brush Set H1 H1E H1F KH500 500 Mach III Triple $22.97
16009-021 Needle Jet 2 each H1 500 $22.50
92071-1011 Rubber Fairing Grommet Set of 8 KZ1000 Z1R Z1-R $22.25
27008-055-01 The Key #901 901 2'em S1 S3 250 400 KH400 Triple $22.16
11012-1025 Fairing Trim Piece Left Cap Set of 4 Z1R Z1-R KZ1000 $22.00
16096-11 Oil Pump Cable Lever S1 S2 S3 250 350 400 Mach I II Kawa $21.99
16021-015 Throttle Stop Screw Idle Adj 750 Mach IV 750 Triple Kaw $21.50
27008-055-23 The Key #923 923 KH500 500 Triple $21.50
92001-045 Chain Adjust Bolt Set of 5 W1 W2 W2SS W2TT Commander $21.50
92015-028 Side Cover Fit Nut 6 ea W1 W2 W2SS W2TT Commander 650 $21.50
92077-020 Side Cover Knob Triple Early S1 S2 250 350 Triple $21.50
27008-055-01 The Key #901 901 2'em S1 S3 250 400 KH400 Triple $21.10
14034-001 Right Hand Engine Cover Cap Avenger A1 S $20.50
18048-003 Exhaust Tail Pipe Tip Chrome Samurai Avenger $20.50
21006-002 Contact Breaker A1 A7 $20.50
18044-007 2 Holder Muffler Connector H1 H2 Mach III IV 500 750 Hi Ted! $20.50
92100-001 Screw Cord Fit Pack 10 H1 H1A H1C Mach III 500 Triple ;Relistin $20.50
13229-003 5 Clutch Metal Spring Ring Big Horn 350 $20.49
35009-036 Chrome Fork Brace S1 250 Triple KH250 Kawasaki NOS $19.99
36014-021 Chain Guard Cover Trail Boss Enduro 100 G4TR NOS K $19.99
46021-009 Frank Brake Lever Assembly G4TR Trail Boss 1970-73 $19.99
13090-012 Stamped Steel Clutch Spring Plate Mach I $19.99
23007-005 Headlamp Headlight Head Light Lamp J1 J1 $19.99
35012-019 Front Fender Bracket F9 Big Horn 350 197 $19.99
35034-010 Brace Rear Fender F5 F8 F9 Big Horn Biso $19.99
36007-016-24 Side Cover Right Candytone Red Roadru $19.99
46019-022 Throttle Grip F9 F11 250 350 Big Horn $19.99
16005-023 Carb Mixing Chamber Top Z1 900 Z-1 DOHC 1973-75 More $19.99
21160-1014 Spark Plug Cap Z1 900 DOHC Z-1 KZ900 KZ1000 KZ1300 $19.99
92071-043 Spark Plug Wire Tension Cord Grommet 500 H1 Mach III $19.99
92100-001 Screw Cord Fit 8'em H1 H1A H1C Mach III 500 Triple $19.99
33040-029 Right Chain Adjuster Early H1 500 Mach III Triple $19.98
291H0610 Screw Slotted 10 each W1 W2 W2SS W2TT Com $19.97
16006-011 Throttle Return Spring Set of 5 W2SS W2TT Commander $19.97
18057-011 Front Muffler Cover Heat Shield F3 Bushwhacker 175 ;Relisting i $19.97
46089-002 Switch Slide Assembly Left $19.97
K14046-103 Complete Engine Gasket Kit 250 F11 ;Relisting item: 2210481228 $19.97
14030-005 Carb Cover G3TR Bushmaster G3SS G4TR Trail Boss KV $19.95
14031-005 Kawasaki Left Hand Engine Cover Roadrunner 120 C2S $19.95
14031-034 Kawasaki C2TR C2SS Roadrunner Left Hand Engine Cov $19.95
23026-004 Lens Tail Light 1966 JL1 JL-1 ? Kawasaki $19.95
13088-028 Clutch Plate Friction Fiber 2 plates H2 750 Mach IV $19.95
16025-021 Throttle Slide 3.0 H1 500 Mach III Triple $19.95
18033-016 Upper Muffler Baffle Tube Samurai 250 A1 $19.93
18033-017 Lower Muffler Baffle Tube Samurai 250 A1 $19.93
18033-054 Kawasaki Exhaust Muffler Baffle 1972 197 $19.93
36014-054-10 Chain Cover Guard KZ400 Early Black N $19.93
56018-016 Side Emblem 90SS 90 SS G3SS Bushmaster K $19.93
27008-055-06 The Key #906 906 2'em S3 KH400 400 Triple $19.49
K14046-107A Engine Gasket Kit MC1M MC1MA KD80 KD80 $18.99
16062-011 Air Inlet Intake Gasket 9 each H1 500 Mach III Triple K $18.99
18070-011 Exhaust Insert H2 750 Mach IV $18.99
27008-055-08 The Key #908 908 2'em S3 KH400 400 Triple $18.99
46125-005 Steering Damper Guide Nut H1 H2 500 750 Triple S1 S2 $18.99
44033-017-14 Left Hand Fork Cover Headlight Bracke $18.70
46106-005 Steering Damper Plate H1 500 Mach III H1A H1C H2 750 $18.55
92015-028 Side Cover Fit Nut 6 ea W1 W2 W2SS W2TT $18.50
11012-1025 Fairing Trim Piece Left Cap Set of 4 Z1R Z1-R KZ1000 $18.50
52018-002 Oil Tank Strap or Band S1 S2 250 350 Triple Mach I II $18.27
27008-027-76 The Key #676 676 Early H1 A/B/C 500 Mach III $18.00
16111-002 Oil Strainer Z1 900 Z-1 DOHC 900 New York Steak $17.99
56001-1080 Right Hand Rear View Mirror KZ550 LTD 1980-83 $17.93
44063-003 Front Axle Fork Holder Z1 900 H2 750 Mac $17.79
27008-055-16 The Key #916 916 KH500 500 Triple $17.23
21155-001 Ihnition Plate Yoke Early H1 Mach III 500 Triple $16.99
46092-012 H1 1969-1972 Clutch Lever 500 Mach III $16.99
92081-042 Clutch Spring 3'em H1 500 Mach III KH500 and more $16.99
14027-003 Point Cover Roadrunner C2 SS TR C2SS C2TR 1967 - 1969 ;Relistin $16.97
13116-011 Clutch Spring Pusher H1 500 Triple Mach III Big Horn $16.96
14019-021 Right Hand Rotary Valve Cover Samurai Ave $16.95
54018-004 Tachometer Tach Cable W1 650 W1SA NOS $16.95
56022-025 Rear Brake Cable KX250 1974 1975 1976 $16.95
56018-016 Side Emblem 90SS 90 SS G3SS Bushmaster $16.93
46096-009 Starter Choke Lever Later H1 500 H2 750 $16.50
92037-006 Muffler Exhaust Clamp W1 650 1966 1967 2 $16.50
92075-090 Meter Bracket Rubber Damper H2 750 Mach $16.50
46059-011 Lever Collar Set of 5 H1 500 H2 750 Commander Z1 900 $16.50
53009-012-10 Seat Hinge Front Black Early H1 500 Mach III $16.50
92115-002 Cord Protector H1 500 Mach III H1A H1C Kawasaki NOS;10 $16.50
1984 1985 1986 NQ50 Spree 50 Honda Service Manual Pre-Owned Part # 61GK802 $16.45
51061-003 Fuel Tank Left Knee Grip Commander Samur $16.19
54018-004 Tachometer Tach Cable W1 650 W1SA $16.10
16067-005 Carburetor Cap Bolt Set of 4 1973 1974 1975 Z1 900 $16.05
27008-055-08 The Key #908 908 S3 KH400 400 Triple $16.05
32132-003 Spark Plug Cover S1 S3 H1 500 H2 750 Mac $16.00
92074-024 Rubber Case Plug Tool Box Tray Handle Z1 900 KZ1000 $16.00
14073-1061 Intake Duct KZ750 1982 1983 1984 Kawasa $15.99
56003-009 Left Hand Rear View Mirror H1 500 H2 750 $15.99
14019-020 Left Rotary Disc Valve Cover Avenger Samurai $15.99
25011-013 Socket Assembly Speedometer Meters G4TR Trail Boss $15.99
25011-013 Socket Assembly Speedometer Meters G4TR Trail Boss Kawa $15.97
18033-057 Kawasaki Exhaust Muffler Baffle 69-75 G3 90 & 76-7 $15.95
1985 1986 1987 CR500 Honda Service Manual Pre-Owned Part # 61KA505 $15.95
1985 1986 CR500 Honda Service Manual Pre-Owned Part # 61KA504 $15.95
1986 ATC200X ATC200 ATC 200 X Honda Service Manual Pre-Owned Part # 61HB500 $15.95
1986 TR200 FatCat Fat Cat 200 Honda Service Manual Pre-Owned Part # 61HB700 $15.95
54001-049 KZ400 Special Speedometer Cable 1975-77 KZ400-S $15.95
Small AC Generator Service Manual John Deere Kohler Honda Homelite Onan Robin $15.95
54012-105 Combination or Throttle Cable Trail Boss $15.95
54012-103 Bushmaster Control Cable G3 G3SS Kawasak $15.93
26004-013 Fuse Assembly S1 250 S3 400 Triple Z1 900 DOHC Four $15.79
27038-002 Horn Bracket Set of 5 Z1 900 DOHC Z-1 1973-75 $15.60
54017-051 Starter Cable Kawasaki NOS 250 350 Triple S1 S2 KH $15.50
54022-021 Rear Brake Cable S1 S2 KH250 250 350 Trip $15.50
44043-033 Fork Top Washer Set of 2 Early H1 Mach III 500 Triple K $15.50
46106-005 Steering Damper Anchor Plate H1 H2 500 750 Triple $15.50
46124-006 Steering Damper Spring Plate H1 H2 500 750 Triple $15.50
18048-015 Exhaust Tip Tail Piece F6 125 F7 175 G5 $15.49
44034-020-10 Right Hand Fork Cover Headlight Brack $14.99
16004-018 Carburetor Cap Mixing Chamber H2 750 Mach IV KT250A2 $14.99
16004-018 Carburetor Cap Mixing Chamber H2 750 Mach IV KT250A2 Ka $14.99
21156-001 Ignition Pick Up Plate H1 Mach III 500 H1A H1C $14.99
46023-008 Right Switch Lower Case Trail Boss GT4 $14.99
K14046-202A Top End Kit Gaskets G3 G4 G5 KE100 KH100 KV100A7 ;Relisting i $14.97
46092-012 H1 1969-1972 Clutch Lever 500 Mach III Kawasaki NO $14.95
46092-012 H1 1969-1972 Clutch Lever 500 Mach III K $14.95
35025-021 Rear Fender Bracket S1 S2 Mach I II 250 350 Triple Kawa $14.95
55011-010 Skid Plate Engine Guard G4 G4TR Trail Bo $14.94
Decal Emblem Left Hand S2 350 Triple Orange 2 Each Mach II $14.59
18048-007 Exhaust Tail Pipe Tip 1969 W2 TT W2TT Co $14.36
13033-027 Wrist Pin Needle Bearing H2 750 Mach IV $13.95
46104-005 Steering Damper Friction Plate H1 H2 500 750 Triple $13.83
92059-078 Airbox Breather Pipe Z1 900 DOHC Z-1 1973-75 $13.79
46032-014 Wiring Harness R Switch W1 W2 W2SS W2TT $13.50
92072-064 Fuel Tank Band F6 F7 125 175 Enduro Kawa $13.50
26009-001 Wiring Harness Cover W1 W2 W2SS W2TT 650 Commander $13.50
55011-010 Skid Plate Engine Guard G4 G4TR Trail Bo $13.49
46106-005 Steering Damper Plate H1 500 Mach III H1 $13.09
52003-015 Oil Cap S2 350 Mach II Triple ;Relisting item: 320940086011. $13.00
46032-013 Wiring Harness Right Switch Avenger Samu $12.99
13159-007 Gear Shift Connector A 250 350 H1 500 H2 750 Triple Kaw $12.99
13159-008 Gear Shift Connector B 250 350 H1 500 H2 750 Triple Kaw $12.99
46058-017 Front Brake Lever KX125 KX250 KX450 Kawasaki NOS $12.99
Oil Pump Lever Cover Early H1 500 Mach III A B C Triple Kawasaki $12.99
18070-007 Exhaust Insert H1 500 Triple Mach III 1973-1976 ;Relisting item $12.97
13091-1063 Air Filter Element Holder KX80 KDX80 1979-81 $12.95
46058-005 Front Brake Lever W1 W2 650 Commander SS TT Samurai Kaw $12.95
23004-3502 Headlight Sealed Beam GE4492 5 3/4" Round Snowmobile Bulb GE 4492 $12.91
92077-020 Side Cover Knob Triple Early S1 S2 250 350 Triple $12.72
92077-009 Knob Left Hand Side Cover F1 175 1960's Kawasaki N $12.50
46041-006 Right Hand Case Upper 1972 H1 H1B 500 Tr $12.50
92083-006 Gear Shift Change Lever Spring W1 W2 SS $12.50
32132-003 Spark Plug Cover S1 S3 H1 500 H2 750 Mach I II IV Kawas $12.50
46124-006 Steering Damper Spring Plate H1 H2 500 750 Triple $12.50
32100-020 Battery Holder Bracket Band KZ900 1976-7 $12.49
11012-1026 11012-1025 Fairing Trim Piece Set Z1R Z $12.00
54012-058 A1 Samurai Combination Cable Low Bar Vers $11.95
27008-055-10 The Key #910 910 S1 S3 250 400 KH400 Triple $11.72
92037-006 Muffler Exhaust Clamp 2'em W1 650 1966 1967 2 each $11.72
46043-003 Switch Knob H1 500 650 Commander W1 W2 W2SS W2TT $11.61
51035-005 Fuel Cock Joint Nut H1 H2 500 750 Triple Mach III IV $11.61
92067-001 Oil Drain Plug 2'em H1 H2 250 350 400 500 750 Triple $11.61
92077-009 Knob Left Hand Side Cover F1 175 1960's $11.50
44041-017 Front Axle Pinch Bolt W1 W2 W2SS W2TT Co $10.50
53009-22 Seat Hinge Front H2 H2B H2C Mach IV 750 Triple $10.50
13094-010 Needle Bearing Big End H1 500 Triple Mach III Kawasaki NOS $10.00
16051-002 Clamp Carb Mount H1 Avenger Samurai Mach III 500 $9.99
1985 1986 CH80 Elite 80 Scooter Honda Service Manual Pre-Owned Part # 61GE101 $9.99
1985 1986 XR600R XR600 R Honda Service Manual Pre-Owned Part # 61KT201 $9.99
1986 1987 XR250R XR250 Honda Service Manual Pre-Owned Part # 61KT101 $9.99
42014-026 Rear Wheel Sprocket Damper KZ550 KZ650 1977-83 Kaw $9.99
46032-013 Wiring Harness Right Switch Avenger Samurai A1 A7 $9.99
14038-030 Right Side Engine Cover Grommet S1 KH250 $9.99
21008-011 Breaker Plate Contact Assembly Avenger S $9.99
23064-009 Headlight Head Light Lamp Bracket Z1 900 $9.99
25002-1052 Suspension Damper Dial Kit KX125 1986 K $9.99
311-5420 Front Brake Cable 1960's Kawasaki NOS $9.99
35027-006 License Plate Bracket MT1 MT-1 Mini Trai $9.99
46023-008 Lower Switch Case Right Hand Trail Boss $9.99
46086-007 Upper Switch Case Left Samurai Avenger W $9.99
46086-013 Upper Switch Case Left Hand Big Horn 350 $9.99
53009-017 Seat Hinge A H2 750 Mach IV Triple S1 S2 $9.99
92027-044 Speedometer Drive Gear Shaft Spacer W1 W $9.99
92060-002 Banjo Bolt Oil Level Gauge 5 of them Ave $9.99
92072-064 Fuel Tank Band F6 F7 125 175 Enduro Kawa $9.99
Manual Assembly & Preparation SS340 SS440 A2 Serie $9.99
Manual Parts Catalog SA340 SA440 SC340 Drifter 340 $9.99
13091-009 Holder Clutch Spring H1 500 Triple Mach III Big Horn Ka $9.99
13142-004 Shift Drum Pin Plate H1 500 Triple Mach III A1 A7 Kawas $9.99
14034-001 Right Hand Engine Cover Cap Avenger A1 Samurai A7 $9.99
16021-015 Throttle Stop Screw Idle Adj 750 Mach IV 750 Triple Kaw $9.99
16067-005 Carburetor Cap Bolt Set of 2 1973 1974 1975 Z1 900 $9.99
16085-017 Oil Pump Gear S1 S2 S3 250 350 400 Mach I II Triple Kaw $9.99
16096-011 Oil Pump Cable Lever S1 S2 S3 250 350 400 Mach I II $9.99
16096-11 Oil Pump Cable Lever S1 S2 S3 250 350 400 Mach I II $9.99
16115-002 Oil Plug Filler Dipstick H2 750 Mach IV Triple $9.99
16115-002 Oil Plug Filler Dipstick H2 750 Mach IV Triple Kawasaki $9.99
16116-005 Drain Grommet H1 A B C 500 Mach III Triple Kawasaki NOS $9.99
21098-007 Clamp Wire Lead 3 each Early H1 500 Mach III Triple $9.99
23050-002 Turn Signal Winker Gaskets 2 each H2 Z1 KZ900 KZ1000 $9.99
26009-001 Wiring Harness Cover W1 W2 W2SS W2TT 650 Commander $9.99
27008-042-01 The Key #701 701 H1B H2A S2 350 500 750 Triple $9.99
27008-048-84 The Key #184 184 S2A 350 Mach II Triple $9.99
27008-055-10 The Key #910 910 S1 S3 250 400 KH400 Triple $9.99
27008-055-16 The Key #916 916 KH500 500 Triple $9.99
33040-050 Chain Adjuster Later H1 D H1D 500 Mach III Triple $9.99
33040-059 Chain Adjuster Later H1 E & F 500 Mach III Triple $9.99
41039-019 Front Drum Hub Collar Z1 900 H2 750 H1 500 $9.99
44015-011 Fork Inner Tube Guide Early H1 Mach III 500 Triple + Ka $9.99
46032-014 Wiring Harness R Switch W1 W2 W2SS W2TT 650 Commander $9.99
46044-003 Switch Knob H1 500 650 Commander W1 W2 W2SS W2TT $9.99
46044-008 Switch Knob B Left H1 500 H2 750 Triple S1 S2 250 350 $9.99
46056-001 Cable Adjuster Lock Nut 2'em H1 A1 A7 Mach III 500 $9.99
46059-010 Lever Collar Set of 2 H1 500 Mach III Triple G31M $9.99
46059-010 Lever Collar Set of 5 H1 500 Mach III Triple G31M $9.99
46086-012 Upper Signal Case Cover Left H1 500 Mach III Triple $9.99
46104-005 Steering Damper Friction Plate H1 H2 500 750 Triple $9.99
51053-003 Gas Cap Hook Spring S2 H1 H2 350 500 750 Triple $9.99
51059-008 Gas Cap Gasket S1 S2 S3 H1 H2 250 350 500 750 Triple $9.99
51063-001 Gas Cap Hook Early S2 H1 H2 350 500 750 Triple $9.99
53009-012-10 Seat Hinge Front Black Early H1 500 Mach III $9.99
53009-022 Seat Hinge Rear Black Select H1 500 H2 Mach III IV $9.99
53009-22 Seat Hinge Rear Black Select H1 500 H2 Mach III IV $9.99
92037-006 Muffler Exhaust Clamp W1 650 1966 1967 2 each $9.99
92072-502 Fuel Tank Band WSAA WSAB Stand Up JetSki Jet Ski $9.99
92087-5001 Tachometer Gear Guide Z1 Z-1 900 KZ900 DOHC NOS;Final $9.99
92115-002 Cord Protector H1 500 Mach III H1A H1C $9.99
99995-221-74 Assembly and Prep Manual 1973 MT1 MT1-B Kawasaki NOS $9.99
27008-048-83 The Key #183 183 S2A 350 Mach II Triple $9.98
13002-020 Piston Wrist Pin H2 750 Mach IV Triple Kawasaki NOS $9.97
13157-002 Gear Toe Shift Rubber 2 Each W1 W2 SS TT Commander ;Relisting i $9.97
13157-003 Shift Rubber B Heal 2 W1 W2 W2SS W2TT Commander 650 ;Relisting $9.97
16024-002 Throttle Valve Stop Rod A1 Samurai 250 A7 Avenger 350 ;Relistin $9.97
25023-003 Meter Socket Cover S1 S2 S3 H1 H2 Mach III IV 500 750 ;Relistin $9.97
25026-001 Meter Ring Chrome S1 S2 S3 H1 H2 Mach III IV 500 750 ;Relisting $9.97
27008-048-85 The Key #185 185 S2A 350 Mach II Triple ;Relisting item: 320 $9.97
53012-002 Seat Latch Spring 3'em Samurai Avenger H1 500 Triple ;Relisting $9.97
92072-064 Fuel Tank Band F6 F7 125 175 Enduro ;Relisting item: 2210625459 $9.97
14030-057-80 Vintage Kawasaki F7 Engine Cover for the Carbur $9.95
23064-006-21 Headlight Bracket Kawasaki 175 Enduro Dual Purp $9.95
28012-006 Refector 500 Mach III H1B Bushmaster G3 B $9.95
35025-021 Rear Fender Bracket S1 S2 Mach I II 250 350 Triple $9.95
46058-012 Brake Lever H1 H1A H1C 500 Mach III F $9.95
54001-049 KZ400 Special Speedometer Cable 1975-77 KZ400-S $9.95
54022-021 Kawasaki Rear Brake Cable S1 S2 KH250 250 350 Trip $9.95
11026-002 Dut Air Cleaner F5 F8 Big Horn Bison $9.95
46086-008 Upper Switch Case Left W1 W2 SS TT Samurai Avenger $9.95
53054-001 Seat Hook Stopper Z1 Z-1 900 KZ550 GPz550 KZ1000 $9.95
34028-034 Front Right Foot Peg Step Trail Boss F6 $9.93
Manual Custom Dressers Honda V45 V65 Magna 1983 Ac $9.93
Manual Vetter Windstar Fairing Owners Manual 1982 $9.93
1985 1986 CR80R Honda Service Manual Pre-Owned Part # 61GC403 $9.91
1986 1987 XL200R XL200 Honda Service Manual Pre-Owned Part # 61KT001 $9.91
Manual Portable Generator GA1000 GA1400 A Series Owners Manual $9.91
Manual Portable Generator GA1800 GA1230 GA3200 A Series Owners Manual $9.91
Manual Portable Generator GD550 A Series Owners Manual $9.91
92075-046 Rubber Damper Main Center Stand H1 Mach III 500 Ka $8.99
54001-006 F1 F2 Speedometer Cable F1060 E012-13 $6.95
16062-016 Air Inlet Intake Gasket 2 'em 750 Mach IV 750 Triple Ka $6.95
13157-004 Shift Pedal Rubber Tip H1 H2 Z1 Samurai $3.02
[i]
