 Coming up August 18th
Coming up August 18th Empty
PostSubject: Coming up August 18th   Coming up August 18th I_icon_minitimeWed Aug 15, 2012 6:43 pm
Here are a few of the items I hope to have listed on eBay this coming weekend -
W1 650 (and more, some early H1 500 Mach III items as well)
92028-084 BUSHING
46098-007 SPACER
14049-003 GASKET
551A0305 PIN DOWEL
42020-003 SPRING
34006-002 SPRING
92022-154 WASHER
92065-037 GASKET
92030-002 LOCK WASHER
92007-018 BOLT HEX HEAD
92081-060 SPRING
92022-089 WASHER
92016-030 NUT LOCK
92065-039 GASKET DRAIN PLUG
52003-013 DIPSTICK
34023-008 SPRING
92028-030 BUSHING
21056-005 PIN CHAIN TENSIONER
92066-012 SCREW
92081-036 SPRING
420B1070 WASHER LOCK 10MM
92087-002 GUIDE TACH
23028-007 GASKET
92065-032 GASKET SPD OR HOUSING
92036-008 CIRCLIP PISTON PIN
92093-005 WASHER RUB
92001-042 BOLT
92016-001 NUT
43005-010 SPRING
18043-002 MUFFLER CONN
92043-037 PIN
671B2575 0 RING
92022-049 WASHER
92076-005 PEG RUBBER
35032-006 HANDLE STAY
23019-017 SCREW
More to come soon -
Thank you!
https://motohorseman.forumotion.com
PostSubject: Re: Coming up August 18th   Coming up August 18th I_icon_minitimeThu Aug 16, 2012 10:57 pm
And some more -
Some triples stuff
12016-1051 ARM ROCKER
14027-023-80 COVER
16062-004 GASKET INTAKE FLANGE
21133-023 CORD
27008-055-09 KEY 909
27031-001 CAP STEERING LOCK
32095-010 BRACKET
32109-1004 BRACKET
33034-008 SLEEVE SWING ARM
33040-026 WASHER
35025-010 BRACKET
35034-007 SUPPORTER
41048-013 SHOE BRAKE
42032-017 SPACER 42032-017
420B1410 WASHER
43057-003 CAP BREATHER
44013-032 FORK TUBE INNER
44033-038-21 Fork Cover LH Black
44034-042-21 R.H. FORK COVER BLK
44039-013 Upper Bracket
44045-035 RUBBER
44063-006 HOLDER
49002-1052 GUIDE VALVE
53057-002 COVER
92004-015 STUD
92016-036 NUT
92030-003 LOCK WASHER
92046-010 BEARING
92061-003 BANJO CONNECTOR
92065-034 WASHER
92075-034 GROMMET
92075-041 RUBBER
92075-275 GROMMET
Have I really been working for 16 hours Shocked
PostSubject: Re: Coming up August 18th   Coming up August 18th I_icon_minitimeFri Aug 17, 2012 11:36 am
OK, this should be the final list, starting Saturday, the 18th, in the afternoon
13161-014 Gear Shift Shaft H1 Mach III 500 Triple 1969-72 Kawasaki NOS 49.99
44013-032 Inner Fork Tube H1 H2 500 750 Triple Mach III IV Kawasaki NOS 125.99
44033-038-24 Left Side Fork Cover Black S2 350 Triple Mach II Kawasaki NOS 39.99
44039-013 Steering Stem Head KH100 G3SS G3TR Bushmaster Kawasaki NOS 49.99
46040-009 R.H. Upper Switch Case W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 9.99
54001-020 Speedometer Cable W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
12001-015 Rotary Valve G31M G31M-A Centurion 1970 1971 Kawasaki NOS 39.99
12004-010 Intake Valve 2'em W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 49.99
16057-002 Needle Jet Spring Seat Set of 5 Z1 900 Z-1 KZ900 1000 Kawasaki NOS 24.99
16061-007 Intake Heat Insulator W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 24.99
16096-011 Oil Pump Cable Lever S1 S2 S3 250 350 400 Mach I II Kawasaki NOS 9.99
27008-020-55 Key #655 655 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
27008-020-56 Key #656 656 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
27008-020-57 Key #657 657 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
27008-020-58 Key #658 658 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
27008-027-69 The Key #669 669 Early H1 A/B/C 500 Mach III Kawasaki NOS 9.99
27008-042-88 The Key #688 688 1972 S2 350 H2 750 Triple Kawasaki NOS 9.99
27008-042-89 The Key #689 689 H1B H2 S2 350 500 750 Triple Kawasaki NOS 9.99
27008-048-84 The Key #184 184 S2A 350 Mach II Triple Kawasaki NOS 9.99
27008-055-01 The Key #901 901 2'em S1 S3 250 400 KH400 Triple Kawasaki NOS 18.99
32030-010 Cylinder Head Brace W1 W1SS W2TT W2SS Commander 650 Kawasaki 9.99
33040-025 Chain Adjuster Set 2 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 14.99
42045-007 Rear Axle Nut Left H W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 9.99
44010-019 Fork Dust Shield S2 S3 350 400 Triple Mach II Kawasaki NOS 9.99
46056-001 Cable Adjuster Lock Nut 3'em H1 A1 A7 Mach III 500 Kawasaki NOS 9.99
46075-007 Left Hand Grip A1 A7 W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 9.99
46086-008 Upper Switch Case Left W1 W2 SS TT Samurai Avenger Kawasaki NOS 18.99
46124-006 Steering Damper Spring Plate H1 H2 500 750 Triple Kawasaki NOS 9.99
46125-002 Steering Damper Nut W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 9.99
53054-001 Seat Hook Stopper Z1 Z-1 900 KZ550 GPz550 KZ1000 Kawasaki NOS 9.99
610A0614 Crankcase Dowel Pin 6x14 10'em Z1 900 KZ900 KZ1000 Kawasaki NOS 24.99
92059-079 Muffler Connector Pipe Set of 2 Z1 900 DOHC Z-1 73-75 Kawasaki NOS 24.99
92072-064 Fuel Tank Band F6 F7 125 175 Enduro Kawasaki NOS 12.99
92081-032 Kick Starter Spring W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki 9.99
14049-003 Hole Cap Gasket 8'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
18043-002 Muffler Connector 2'em W1 Commander 650 Kawasaki NOS 9.99
21056-005 Chain Tensioner Pin 4'em W1 W2 W2SS W2TT Commander 650 Kawasaki 24.99
23019-017 Focus Adj Screw 4'em Samurai Avenger Commander 650 Kawasaki NOS 9.99
23028-007 Tail Light Gasket Samurai Avenger Commander 650 Kawasaki NOS 9.99
34006-002 Foot Rest Spring H1 500 Samurai Avenger Commander 650 Kawasaki NOS 9.99
34023-008 Side Stand Spring W1 W1SS W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
35032-006 Rear Fender Stay Right W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 24.99
42020-003 Rear Brake Springs H1 500 W1 W2 W2SS W2TT Commander 650 Kawasaki 9.99
420B1070 Tongued Lock Washer 10MM W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
43005-010 Brake Pedal Spring W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
46037-012 RH Switch Wiring Holder Samurai Avenger Commander 650 Kawasaki NOS 9.99
46098-007 Steering Stem Cap W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
52003-013 Oil Tank Dip Stick W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
551A0305 Dowel Pin 3x5mm 40'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
671B2575 Generator O-Ring 75mm 3' W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92001-042 Damper Sleeve Bolt 4'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92007-018 Hand Lever Bolt 10'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 24.99
92016-001 Damper Lock Nut 3'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92016-030 Valve Adj Lock Nut 5'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92022-049 Spring Washer 13 H1 500 Samurai Avenger Commander 650 Kawasaki NOS 9.99
92022-089 Kickstart Washer 2'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92022-154 Plain Washer 87M 6'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92028-030 Small End Bushing 2'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92028-084 Speedo Gear Bushing 3'em W1 W2 W2SS W2TT Commander 650 Kawasaki 12.99
92030-002 Oil Pump Lock Washer 4'em W1 W2 W2SS W2TT Commander 650 Kawasaki 9.99
92036-008 Piston Pin Circlip 8'em W1 W2 W2SS W2TT Commander 650 Kawasaki 9.99
92043-037 Foot Stand Pin 3'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92065-032 Speedo Housing Gasket W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92065-039 Oil Tank Gasket 10'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 14
92066 Camshaft End Plug 10'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 11.99
92076-005 Rubber Foot Peg 1'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92081-036 Clutch Spring Set 5'em W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92081-060 Kickstart Pedal Spring W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92087-002 Tachometer Shaft Guide W1 W1SS 650 Kawasaki NOS 9.99
12016-1051 Rocker Arm Ninja Eliminator 900 500 Vulcan EX500 Kawasaki NOS 32.99
14027-023-80 Breaker Points Cover Z1 900 DOHC KZ900 LTD KZ1000 Kawasaki NOS 49.99
16062-004 Intake Flange Gasket W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
21133-023 Left Spark Plug Cord Wire 1972 H1 H1B 500 Triple Kawasaki NOS 9.99
27008-055-09 The Key #909 909 2'em S3 S3A KH400 400 Triple Kawasaki NOS 24.99
27031-001 Steering Lock Cap 3'em KZ1000 Z1R 250 350 400 Triple Kawasaki NOS 9.99
32095-010 Side Cover Bracket H2 H2A 750 Triple Mach IV Kawasaki NOS 9.99
32109-1004 Frame Hand Grip 1979-80 KZ1000 + the Z1R Z1-R Kawasaki NOS 24.99
33040-026 Right Chain Adjuster 2 W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
35025-010 Rear Fender Bracket H1 H1/A/B/C 500 Mach III Triple Kawasaki NOS 19.99
35034-007 Rear Fender Supporter H1 500 Triple Mach III H1A H1C Kawasaki NOS 24.99
41048-013 Rear Brake Shoe Set H1 500 Triple Mach III KH500 Kawasaki NOS 23.99
42032-017 Rear Axle Collar Spacer H1 500 Triple Mach III KH500 Kawasaki NOS 23.99
420B1410 Camshaft Lock Washer 8 W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
44045-035 Fork Cover Rubber 4 1972 H1 H1B 500 H2 H2A 750 Triple Kawasaki NOS 9.99
44063-006 Front Axle Holder S2 S3 S3A 350 400 Mach II Triple Kawasaki NOS 23.99
49002-1052 Valve Guide 2 Ninja Eliminator 900 500 Vulcan EX500 Kawasaki NOS 18.99
53057-002 Back Rest Cowl Cover H1 500 Mach III Triple KH500 Kawasaki NOS 23.99
92004-015 Stud 6x78 Transmission W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92016-036 Shift Pawl Nut 16mm W1 W2 W2SS W2TT Commander 650 Kawasaki NOS 9.99
92030-003 Generator Gear Lock Washer W1 W2 W2SS W2TT Commander 650 Kawasaki 9.99
92046-010 Transmission Bearing H1 500 H2 750 Mach III IV Triple Kawasaki NOS 9.99
92061-003 Banjo Connector A1 A7 H1 Mach III 500 Big Horn Kawasaki NOS 9.99
92065-034 Gear Box Drain Bolt Gasket W1 W2 W2SS W2TT Commander 650 Kawasaki 16.99
92075-034 Meter Damper 4'em A1 A7 H1 W1 W2 W2SS W2TT Commander 650 Kawasaki 9.99
92075-041 Side Cover Damper (2) 1972 H2 750 Mach IV W1 W2 TT/SS Kawasaki NOS 9.99
92075-275 Handlebar Damper H1 H2 500 750 Mach III IV Triple Kawasaki NOS 9.99
Motohorseman :: Central Missouri Motorcycle Riders :: Craigslist Ebay and other finds-
