Share |
 KAWABUNDEALS!
PostSubject: KAWABUNDEALS!   Mon Nov 05, 2012 5:11 pm
5 day auctions starting now - Monday the 5th - Kawasaki Bundle Deals!
K01 1 46078-003 Left Switch Button Assembly W2 W2SS W2TT 650 S1 250
1 46044-011 Switch Knob Left H1 500 H2 750 Triple S1 S2 250 350
3 46089-007 Slide Block Left Switch H1B H2A 500 750 Triple
7 46079-001 Horn Contact Button Set of 5 H1 500 Wseries Commander
K02 1 41039-028 Front Drum Hub Collar KH400 KH500 400 500 Triple
1 92027-133 Right Hand Crankshaft Collar H2 750 Mach IV Triple
25 92027-241 Collar 10'em 1974 Z1 Z1B Headlight S3 Triple Fender
1 42032-030 Rear Axle Collar Right Side All H2 750 Mach IV Triple
K03 2 92075-275 Handlebar Damper H1 H2 500 750 Mach III IV Triple
3 32101-008 Side Cover Damper Plate 1.6T H1 500 Mach III KH500
2 25019-013 Meter Damper Rubber 2 each H1 H2 Mach III IV 500 750
5 25019-014 Indicator Light Damper 3 ea H1 H2 Mach III IV 500 750
K04 2 92043-126 Gas Cap Hook Pin 2'em H1 500 KZ900 and more
3 16007-002 Throttle Valve Spring Seat Avenger Samurai S1 Mach I
2 16007-007 Throttle Valve Spring Seat Avenger Samurai S1 Mach I
1 92043-094 Fuel Cap Fitting Pin H2 H2A 750 Mach IV Triple S1 250
K05 2 18067-003 Exhaust Gasket 2'em S1 S2 Mach I II 250 350 Triple
5 23028-018 Tail Lamp Light Gasket 3'em H2 Mach IV 750 Triple Z1
3 52019-001 Chain Oiler Cap Gasket Set of 2 H2 750 Triple Mach IV
K06 2 13116-019 Long Clutch Push Rod S1 S2 S3 250 350 400 Triple KH
2 43005-033 Rear Brake Pedal Spring S1 S2 S3 KH250 KH400 F6 F7
6 92075-105 Fender Damper Set of 4 250 400 KH250 KH400 Triple
4 21133-022 Right Coil Wire S1 S2 S3 250 KH250 350 400 Triple
1 42037-024 Rear Axle Collar S1 B/C 250 S3 400 KH250 KH400 Triple
14 92024-035 Lock Washer 6'em S1 250 S2 350 S3 400 KH250 Triple
1 16017-066 Needle Jet O-2 S1 250 KH250 Triple Mach I
K07 2 92015-041 Brake Cable Adj Nut H1 500 Triples A1 A7 W1 W2 Commander
1 92020-003 Shock Acorn Nut H1 500 H2 750 Samurai Avenger More
5 92081-151 Shift Lever Spring 5'em KH500 500 Triple
9 13170-004 Shift Linkage Plate Set of 9 A1 A7 H1 500 H2 750
K08 2 41027-046 Rear Inner Spoke 2'em S1 S2 250 350 Triple KH400
27 41027-047 Rear Inner Spoke Set 10 H1 500 Triple KH500
18 41027-085 Spoke Assembly Inner 8'em H1 500 KZ650 KZ750 KZ900
K09 3 34023-016 Centerstand Main Stand Spring H1 500 Mach III KH500
3 13070-001 Kick Spring Guide 3 each H1 500 H2 750 Mach III IV +
5 46106-006 Steering Damper Plate 2! S2 H1 H2 350 500 750 Triple
4 46124-002 Steering Damper Spring Washer 4'em H1 500 Mach III
K10 9 92022-106 Turn Signal Washer 9'em H2 H2A 750 Triple Mach IV
7 92026-026 Thrust Washer A1 A7 H1 H2 500 750 Mach III IV Triple
6 92026-024 Side Washer 6'em Samurai Avenger H1 500 Mach III
7 92022-076 Transmission 25mm Washer 7'em A1 A7 H1 H2 500 Triple
K11 2 92028-075 Tach Bushing 2'em H1 500 H2 750 Mach III IV Triple
7 92028-071 Shift Bushing S1 S2 S3 H1 500 H2 750 Mach III IV
1 43052-002 Brake Shaft Dust Seal 4'em A set S2 350 S3 400 Triple
2 51038-005 Fuel Strainer All H1 & H2 500 750 Mach III IV Triple
1 92050-027 Rear Hub Oil Seal H1 H2 500 750 Mach IV Triple Z1 900
1 600A0800 1/4" Steel Ball 7'em H1 H1 W1 W2 Commander Triple Z1
_________________
Ride for one - Ride for all
http://motohorseman.forumotion.com
KAWABUNDEALS!
Motohorseman :: Central Missouri Motorcycle Riders :: Craigslist Ebay and other finds-
