 Metropolitan/Ruckus Radiator Check
Metropolitan/Ruckus Radiator Check Empty
PostSubject: Metropolitan/Ruckus Radiator Check   Metropolitan/Ruckus Radiator Check I_icon_minitimeSun Feb 10, 2013 4:48 pm
I've not seen or heard of a Metropolitan or Ruckus overheating, but still suggest owners check and clean (if needed) the radiator fins.
There are four screws, the cover snaps off - look around wiggle it, it will come off after the screws are removed.
Use a lot of caution in cleaning the fins, they bend easily and that will block air flow. You can vacuum them off or blow them out from the back - there are a couple holes you can spray high pressure air into.
Again, be careful, don't go jamming anything in or around the radiator, it can be damaged.
Here is ours -
Metropolitan/Ruckus Radiator Check MetRadiator_zpsababb3fb
Just take a look, you will be able to easily tell if it needs to be cleaned.
Thank you
» How do I check if I'm getting spark?
» Horse for sale, check him out
» rzr radiator hose rubbing
» SHB Check these Out
» Radiator Thermo Switch
Motohorseman :: Central Missouri Motorcycle Riders :: Scooters-
