 Metropolitan Seat Latch Modification
Metropolitan Seat Latch Modification Empty
PostSubject: Metropolitan Seat Latch Modification   Metropolitan Seat Latch Modification I_icon_minitimeSat Mar 30, 2013 6:29 am
Here is my version of a modification for a "emergency" linkage to open the seat
1st, remove the seat. 1 phillips screw on the centerstand lock lever and the 4 10mm bolts.
Use a good old fashioned hanger - Here is how I bent the end to fit on this style release lever -
Metropolitan Seat Latch Modification WireEnd_zpse0d2735f
Use a small wire tie/zip strip to hold it on AFTER you have competed intial installation -
Note the small hole drilled to allow the wire to exit into the left fenderwell
Metropolitan Seat Latch Modification CIMG7628_zpsd047a38e
After the "rod" has been run through, bend it to fit -
Metropolitan Seat Latch Modification CIMG7629_zps429f6391
First, add a small piece of rubber tubing to the end
Metropolitan Seat Latch Modification CIMG7632_zpsb4228849
That makes it easier to bend my hand and more comfortable to use
Another shot -
Metropolitan Seat Latch Modification CIMG7633_zpsd2bb1f37
Never be locked out of the storage compartment again
_________________
Ride for one - Ride for all
http://motohorseman.forumotion.com
PostSubject: Re: Metropolitan Seat Latch Modification   Metropolitan Seat Latch Modification I_icon_minitimeSat Mar 30, 2013 8:38 am
I discovered some Metropolitans may have a slightly different latch release - here are pictures to cover the mod on those.
Here you can see the zipstrip/wire tie is inserted through the latch release, then on to the metal hanger section. -
Metropolitan Seat Latch Modification CIMG7635_zpsa6eb8f68
Here is the basic routing, note the finger pull
Metropolitan Seat Latch Modification CIMG7636_zps68f6c65f
Do not bend the finger pull until you have installed the metal hanger and slipped the plastic cover on the metal hanger section.
and the battery cover will require a modification on either version
Metropolitan Seat Latch Modification CIMG7640_zps287724eb
_________________
» wanted -- van swivel seat
» Commander rear seat and cage.
» RZR rear seat and cage.
» 4 seat Rhino cage
» New Fuel Seat Beard Seats
Motohorseman :: Central Missouri Motorcycle Riders :: Scooters-
