 September - Coming up
September - Coming up Empty
PostSubject: September - Coming up   September - Coming up I_icon_minitimeThu Sep 06, 2012 7:34 am
We've enter the phase of lots of smalls at Independence Kawasaki. We'll have a few more Triple and W series items, as well as some vintage motocross items.
Thank you for your interest!
Steve
https://motohorseman.forumotion.com
PostSubject: You saw it here first!   September - Coming up I_icon_minitimeThu Sep 06, 2012 9:29 pm
Item Description
16006-012 SPRING
16082-041 HOLDER
23028-008 GASKET
23028-018 GASKET
27007-003 NUT.
34023-016 SPRING
41069-032 COLLAR
41069-033 NUT
43005-011 SPRING
43045-006 BOLT
46092-006 CLUTCH LEVER A/F1/W/
46092-012 CLUTCH LEVER
601B6302 BEARING BALL
601B6304 BEARING
670B2016 O RING
92003-165 BOLT
92015-049 NUT CYL
92024-035 SHIM
92026-026 THRUST WASHER
92028-074 BUSH H
92028-081 BUSHING 25X30X34L
92046-004 HEARING
92065-055 GASKET
92083-002 SPRING
More tomorrow - KX125 KX250 goodies
PostSubject: Re: September - Coming up   September - Coming up I_icon_minitimeFri Sep 07, 2012 9:42 pm
No promises, I'm trying to get these posted to start Saturday the 8th
16019-004 Float Gasket
23005-022-21 Headlight Bucket
13008-030 RING SET
13029-063 PISTON
14069-1001 BREATHER ASSY
16013-009 SPRING STATER
18050-004 GASKET
18062-004 HOLDER
18071-003 SPRING CONNECTOR
21013-024 CONDENSER
21049-014 COIL PRIMARY
26004-014 Fuse Assy
12001-021 VALVE
13068-022 GEAR
13118-005 RELEASE OUTER
13130-026 2ND GEAR
13132-023 3RD GEAR
13133-023 GEAR
13134-010 GEAR
13135-014 GEAR
13136-033 GEAR
13137-018 GEAR
13168-017 PAWL
14063-002 FILTER
14065-001 CAP
16116-001 FUEL PIPE OVERFLOW
32030-020 PLATE ENGINE MOUNT
33040-043 ADJUSTER
41069-004 SPACER
42010-015 BEARING SPACER
44041-007 BOLT
92001-087 BOLT
92006-002 STUD
92027-101 COLLAR
92082-002 SPRING
92090-006 NUT LOCK
13036-034 Crankshaft Assy
12053-1017 GUIDE CHAIN
13033-1001 Small End Needle Bearing
16126-1003 CAP AIR
32099-1014 CASE R.H. UPPER
42036-1010 SLEVE REAR BRAKE
44029-1005 CAP FORK TOP KX250
44029-1009 CAP RUBBER
46094-014-21 HOLDER CLUTCH LEVER
51049-1006 CAP
16031-029 FLOAT
56018-1024 EMBLEM SIDE
56018-1089 EMBLEM SIDE
92073-025 CAP
11009-1178 GASKET
12053-1030 GUIDE CHAIN
12053-1044 GUIDE CHAIN
33040-1009 CHAIN ADJUSTER KX80
59051-1015 GEAR KICK 31T
92015-1062 NUT
92027-1089 COLLAR
92027-1094 COLLAR FRONT
92037-1130 CLAMP MUFFLER
92075-1066 DAMPER FUEL TANK
92093-1019 DUST SHIELD FORK OUT
26001-1027 Wiring Harness
23026-009 Tail Light Lens
PostSubject: Re: September - Coming up   September - Coming up I_icon_minitimeThu Sep 13, 2012 2:13 pm
Working on these now.....
Item Description
12002-020 ROT. DISC. VALVE & COLLAR A Series
13029-016 PISTON A Series
13088-008 CLUTCH PLATE A Series
13093-004 RETURN RUBBER LONG A Series
13119-003 PLATE CLUTCH RELEASE A Series
13129-014 LOW GEAR OUTPUT A Series
13132-009 GEAR A Series
13137-007 TOP GEAR OUT PUT A Series
13141-012 DRUM A Series
13168-004 0.441 A Series
14031-029 COVER A Series
14038-008 RUBBER COVER A Series
16009-012 NEEDLE JET A Series
16024-002 ROD THROTTLE VLV STOP A Series
16084-005 GEAR A Series
16087-002 VALVE CHECK A Series
18068-003 RUBBER SEAL A Series
21008-011 BREAKER ASSY A Series
21013-007 CONDENSER A Series
21013-008 CONDENSE A Series
21020-001 LEVER A Series
21058-001 GEAR IDLE A Series
21061-005 RECTIFIER A Series
21069-006 GEAR A Series
32109-010 GRIP FRAME A Series
44006-011 FORK LEG A Series
44030-005 GUIDE FORK COVER A Series
44033-030-10 COVER L.H. FORK BLK A Series
44039-015 TRIPLE TREE UPPER A Series
46102-005 STUD A Series
55011-005 PLATE A Series
92003-013 BOLT HEX HEAD 8X8 A Series
92042-009 SPACER A Series
92060-014 BOLT BANJO. A Series
92075-042 DAMPER RUBBER DUAL SEAT A Series
16037-002 CAP A Series F9
46024-002 RETAINER A Series F9 G4TR
14038-006 IDLE ADJUST CAP A Series G3/G4SS
92026-025 THRUST WASHER A Series Triples F9
42014-020 DAMPNER RUBBER F11M
14038-031 GROMMET CARE CAP F81M
14065-003 CAP F81M
92047-003 CONE STEERING F9 Big Horn F11/81M
92081-069 SPRING CLUTCH RELEASE F9 Big Horn F11/81M
13168-016 LEVER F9 Big Horn F81M
14040-003 GROMMET F9 Big Horn F81M
46098-005 CAP F9 Big Horn F81M
13231-1008 RELEASE ASSY MC1
16009-059 JET NEEDLE MC1
16147-001 PLUG CARE MC1
18070-005 INSERT EX MC1
92036-003 PISTON CIRCLIP MC1
92075-117 DAMPER RUBBER CYL HD MC1
23008-021 Head Light Socket MC1 G3/G4SS
41039-002 SPACER,FRONT HUB MC1 G3/G4SS
92024-003 LOCK WASHER MC1 G3/G4SS
92028-025 BUSH MC1 G3/G4SS
92028-069 BUSHING MC1 G3/G4SS
44041-040 BOLT FORK CYL Multiple A
92020-003 ACORN NUT Multiple A
21019-011 FELT,OIL Triples
21023-009 PAN HEAD SCREW Triples
Possibly more, possibly less.....
PostSubject: Re: September - Coming up   September - Coming up I_icon_minitimeThu Sep 20, 2012 7:09 pm
Starting Saturday the 22nd at 2:00PM Left Coast Time - One every 3 minutes!
Description and opening bid amount -
A05 13162-007 Gear Change Lever S2 350 G31-M 100 Green Streak G3SS Kawasaki NOS $36.99
A05 18033-011 Baffle Tube Long Muffler C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A05 21048-004 Magneto Base C2SS C2TR Roadrunner 120 MT1 MT-1 KV75 Kawasaki NOS $9.99
A05 23005-008-10 Headlight Body C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $32.99
A05 25005-019 Speedometer C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $49.99
A05 44027-001 Fork Cover Gaiter 2'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $16.99
A05 44033-011 Left Fork Cover Bracket C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $14.99
A05 44034-010 Right Fork Cover Bracket C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $14.99
A12 14030-025 Oil Pump Cover Early H1 500 Mach III Used Kawasaki Part $49.99
A12 23005-038-21 Headlight Shell Bucket 1974 H1 500 Mach III Used Kawasaki Part $9.99
A12 25005-027 Speedometer Early H1 500 Mach III A1 A7 SS Used Kawasaki Part $49.99
A12 25015-006 Tachometer Tach Early H1 500 Mach III Used Kawasaki Part $49.99
A12 25015-026 Tachometer Speedometer 1974 H1 500 Mach III Used Kawasaki Part $49.99
A12 27003-014 Horn Honks H1 500 Mach III W1 W2 Commander 650 Used Kawasaki Part $9.99
A12 27005-021 Ignition Switch with Key Early H1 500 Mach III Used Kawasaki Part $24.99
A12 46018-008 Throttle Case Assembly Early H1 500 Mach III Used Kawasaki Part $24.99
A12 46091-047 Left Switch Assembly 1974 H1 500 Mach III Used Kawasaki Part $24.95
A12 46101-004 Steering Damper Knob Assembly H1 500 Mach III Used Kawasaki Part $24.99
A12 46132-019 Throttle & Switch Assembly 1974 H1 500 Mach III Used Kawasaki Part $24.95
A15 13036-043 Crankshaft Assembly MC1 MC-1 Bushmaster Trail Boss Kawasaki NOS $149.99
A15 21129-003 Ignition Coil w/ Wire F1 F1TR F2 F2TR 175 B8 B8S 125 Kawasaki NOS $43.99
A16 11001-018 Cylinder Head 1966-69 F2 Street F2TR Enduro 175 Kawasaki NOS $39.99
A16 11001-030 Cylinder Head F4 1968-70 Sidewinder 250 Enduro Kawasaki NOS $49.99
A20 13044-009 Connecting Rod Set F5 Big Horn 350 F8 Bison 250 Kawasaki NOS $63.99
A20 13069-004 Kickstarter Pawl 4'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 13089-004 Metal Clutch Plate 3'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $19.99
A20 13102-004 Inner Clutch Release G31-M Centurion Green Streak 100 Kawasaki NOS $16.99
A20 13129-1053 4th Drive Gear Trail Boss G31-M 100 Green Streak Kawasaki NOS $24.99
A20 13177-002 High Gear C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $34.99
A20 13177-003 Counter Gear C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $18.99
A20 18065-001 Muffler Insulator 4'em G31-M 100 Green Streak G3SS Kawasaki NOS $9.99
A20 18069-030 Exhaust Header Pipe Clamp C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $11.99
A20 21013-016 Ignition Condenser 2'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 21047-004 Lighting Coil C2SS C2TR Roadrunner 120 MT1 MT-1 KV75 Kawasaki NOS $22.99
A20 21047-009 Lighting Coil B C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $12.99
A20 21048-008 Magneto Base C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $12.99
A20 21049-003 Primary Coil C2SS C2TR Roadrunner 120 MT1 MT-1 KV75 Kawasaki NOS $51.99
A20 21049-008 Primary Coil C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $16.99
A20 23061-003 Earth Plate 7'em 350 H1 500 H2 750 Mach III IV Triple Kawasaki NOS $16.99
A20 27003-005 Nikko Horn 6V 1A C2 C2SS C2TR Roadrunner 120 SS TR Kawasaki NOS $12.99
A20 27018-004-893 Key #283 283 2'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 291Z0620 Slotted Clutch Screw 4'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 33034-001 Swingarm Sleeve 2'em G31-M 100 Green Streak F3 F4 Kawasaki NOS $9.99
A20 34003-018 Left Foot Rest Bar G31-M 100 Green Streak G4TR KV100 Kawasaki NOS $12.99
A20 41069-002 Front Hub Collar 3'em C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 43067-001 Banjo Bolt Washer 5'em H1 H2 Z1 500 750 Triple 900 Kawasaki NOS $9.99
A20 44041-016 Top Fork Bolt 2'em 1969 C2 C2SS C2TR Roadrunner 120 Kawasaki NOS $21.99
A20 44043-034 Fork Cover Washer 3'em Early H1 500 Triple Sidewinder Kawasaki NOS $12.99
A20 44046-015 Fork Top O-Ring 7'em H1 500 H2 750 Triple Sidewinder Kawasaki NOS $9.99
A20 46010-002 Lower Handlebar Holder 2'em C2SS C2TR Roadrunner 120 Kawasaki NOS $9.99
A20 46022-006 Right Hand Lower Switch Case Very Vintage Unknown Fit Kawasaki NOS $9.99
A20 46092-1002 Front Brake Lever KH400 Triple KZ650 KZ750 KZ1000 Kawasaki NOS $16.99
A20 46100-002 Steering Damper Wave Washer S2 H1B H2 500 750 Triple Kawasaki NOS $9.99
A20 56018-1432 Pulsing Coil Cover Mark KZ550 Spectre ZN700/1100 LTD Kawasaki NOS $18.99
A20 92007-020 Hex Head Bolt 6'em Roadrunner Avenger Commander 650 Kawasaki NOS $9.99
A20 92020-005 Rear Shock Nut 4'em C2 C2SS C2TR 120 SS TR Roadrunner Kawasaki NOS $9.99
A20 92022-144 Transmission Shim H1 500 H2 750 Triple F81-M Big Horn Kawasaki NOS $9.99
A20 92024-026 14mm Tongued Lock Washer 14'em S1 250 S2 350 Triple Kawasaki NOS $9.99
A20 92026-024 Side Washer 6'em Samurai Avenger H1 500 Mach III Kawasaki NOS $27.99
A20 92027-241 Collar 10'em 1974 Z1 Z1B Headlight S3 Triple Fender Kawasaki NOS $14.99
A20 92028-075 Tach Bushing 2'em H1 500 H2 750 Mach III IV Triple Kawasaki NOS $19.99
A20 92046-1038 Wrist Pin Needle Bearing 3'em H1 500 Mach III A1 A7 Kawasaki NOS $24.99
A20 92052-001 Oil Seal Rear Hub 2'em C2SS C2TR 120 MC1 Roadrunner Kawasaki NOS $9.99
A20 92055-026 Oil Cap O-Ring 5'em G31-M 100 Green Streak G4TR KV100 Kawasaki NOS $9.99
A20 92065-072 Engine Right Gasket Round 5'em Early H1 500 Mach III Kawasaki NOS $9.99
A20 92076-007 Rear Footrest Rubber 2'em Sidewinder Roadrunner more Kawasaki NOS $9.99
A20 92091-002 Frame Stud 10x225mm S1 S2 S3 KH250 KH400 Triple A1 A7 Kawasaki NOS $9.99
A20 92114-002 Cord Protector Clip 4'em Early H1 500 Mach III Triple Kawasaki NOS $9.99
A21 14038-011 Carburetor Cover 2'em A1 Samurai A7 Avenger F3 SS Kawasaki NOS $9.99
A21 16116-001 Fuel Overflow Pipe A1 A7 F5 F8 F81-M F9 Green Streak Kawasaki NOS $9.99
A21 23028-018 Tail Lamp Light Gasket 3'em H2 Mach IV 750 Triple Z1 Kawasaki NOS $9.99
A21 26004-014 Fuse Assembly F11 F11M F11-M 250 MX Dual Sport Kawasaki NOS $9.99
A21 27007-003 Ignition Switch Nut 2'em H1 500 H2 750 Triple KH Kawasaki NOS $9.99
A21 27008-055-01 The Key #901 901 2'em S1 S3 250 400 KH400 Triple Kawasaki NOS $24.95
A21 42020-003 Rear Brake Springs 2 sets H1 500 W1 W2 Commander 650 Kawasaki NOS $19.99
A21 43033-004 Brake Lever Bolt 3em KH400 KH500 H2 750 Mach IV KZ900 Kawasaki NOS $19.99
A21 46021-013 Front Brake Lever Assembly S2 S2A 350 Mach II Triple Kawasaki NOS $24.99
A21 46077-014 Lower Switch Case Left w/ Lever Early H1 500 Mach III Kawasaki NOS $9.99
A21 46092-006 Clutch Lever Samurai Avenger W2SS W2TT Commander 650 Kawasaki NOS $9.99
A21 46094-014-21 Clutch Lever Holder KX125 KX250 KDX250 KDX400 + Kawasaki NOS $28.99
A21 92046-004 Clutch Needle Bearing A1 A7 H1 H2 Mach III IV Triple Kawasaki NOS $9.99
A21 92072-015 Battery Band Strap A1 Samurai A7 Avenger 250 350 Twin Kawasaki NOS $9.99
A21 92075-034 Meter Damper 4'em A1 A7 H1 W1 W2 W2SS W2TT Commander 650 Kawasaki $9.99
SLF 42048-005 Rear Wheel Assembly Bushmaster Trail Boss G5 KE100 Kawasaki NOS $99.99
SLF 42048-008 Rear Wheel Assembly H1 500 Mach III 1969-1972 Kawasaki NOS $179.99
SLF 53001-1124 Dual Seat Assembly KZ440 LTD 1980-1983 Kawasaki NOS $241.99
SLF 53001-1272 Seat Assembly 1980-82 KX80 1980-83 KDX80 Kawasaki NOS $79.99
SLF 53001-1452 Seat Assembly 1982-1990 KE100 Kawasaki NOS $174.99
PostSubject: Final weekend of September 2012   September - Coming up I_icon_minitimeThu Sep 27, 2012 1:46 pm
Part Number / Description /Opening Bid and the reserve amount
13044-005 Connecting Rod Assembly Pin Bearing F4 Sidewinder 250 $57.99
14028-004 Engine Cover Hole Cap W1 W2 W2SS W2TT Commander 650 $9.99
14051-003 Check Valve Gasket 7'em H1 H2 500 750 Mach III IV F9 $9.99
14065-003 Air Filter Holder F81M F81-M Green Streak 250 MX $9.99
18057-019 Rear Exhaust Muffler Cover F3 Bushwhacker 175 $9.99
21008-011 Breaker Point Plate Assembly A1 Samurai A7 Avenger $16.99
23019-021 Headlight Adjustment Screw 2em A1 A7 H1 H2 500 750 Z1 $9.99
23020-017 Headlight Nut 4'em S2 350 II H2 750 Mach IV Triple $9.99
26001-023 Main Electrical Wiring Harness F3 Bushwhacker 175 $49.99
27002-015 Turn Signal Relay G3SS 90 SS TR Bushmaster F9 350 $23.99
291Z0622 Slotted Clutch Adjust Screw 4'em H1 500 Mach III S1 S2 $9.99
32030-016 Rear Engine Holder Plate Mount H1 H2 500 750 Triple $9.99
41025-052 Front Rim 18" 1.60Ax18 S1 S2 250 350 Avenger Samurai $79.99
41025-072 DID Alloy Rear Rim 2.15Bx18 18" KX250 KX450 More! $79.99
43052-002 Brake Shaft Dust Seal 4'em A set S2 350 S3 400 Triple $9.99
44045-029 Fork Cover Gasket 2'em F4 S1 S2 S3 H1 500 Mach III $9.99
46100-001 Steering Stem Washer 5'em A1 A7 SS H1 500 Mach III $9.99
46124-002 Steering Damper Spring Washer 2'em H1 500 Mach III $9.99
56018-099 Oil Tank Emblem 1972 H1 H1B H1C 500 Mach III Triple $9.99
56018-127 Oil Tank Emblem Trail Boss G4TR D&E G5 C 100 Enduro $9.99
60A0800 1/4" Steel Ball 7'em H1 H1 W1 W2 Commander Triple Z1 $9.99
92004-029 Exhaust Stud 2'em Select H1 500 Mach III Triple $9.99
92015-009 6mm Acorn Nut 8'em Gauges Mach IV 750 H2 Triple $9.99
92022-075 Transmission 17mm Washer 2'em A1 Samurai A7 Avenger $9.99
92022-076 Transmission 25mm Washer 5'em A1 A7 H1 H2 500 Triple $9.99
92022-113 Transmission Thrust Washer H1 H2 500 750 Triple F81-M $9.99
92022-218 Generator Washer 5'em 8.5X23.5X4.5 Z1 Z-1 900 DOHC $11.99
92022-248 20mm Axle Washer 4'em H2 750 Mach III Z1 Z-1 900 DOHC $11.99
92024-015 18mm Lock Washer 6'em H1 500 Mach III Triple KX450 MX $9.99
92024-034 Trans Lock Washer 7'em S1 S2 S3 250 350 400 Triple $9.99
92025-054 Front Engine Shim 0.8mm 6'em H1 H2 500 750 Triple $9.99
92037-040 Oil Level Pipe Clamp 3'em Early H1 500 Mach III A1 A7 $9.99
92041-003 Cotter Pin Seat Hinge Pin 5em H1 H2 500 750 Z1 Triple $9.99
92043-009 Shift Spring Pin 7'em H1 H2 500 750 Triple $9.99
92043-024 Shift Linkage Pin 3'em Early H1 500 Mach III Triple $11.99
92043-094 Fuel Cap Fitting Pin H2 H2A 750 Mach IV Triple S1 250 $9.99
92050-027 Rear Hub Oil Seal H1 H2 500 750 Mach IV Triple Z1 900 $9.99
92075-158 Blinker Damper 4'em H1 H2 500 750 Mach IV Triple $9.99
92081-151 Shift Lever Spring 5'em KH500 500 Triple $11.99
92101-001 Spark Plug Cap Wire Spring 4'em H1 H2 500 750 Triple $9.99
All items are NOS Kawasaki
» Coming up or ???
» Coming up August 18th
» Coming Soon: October 20th
» Coming up - Saturday July 28th 2012
» Sneak Preview - Coming up August 11th
Motohorseman :: Central Missouri Motorcycle Riders :: Craigslist Ebay and other finds-
