These plus a few -
Item # / Description / Opening Bid / Start time
59096-502 Crankshaft Labyrinth Seal Jet Ski JS400 Kawasaki NOS $9.99 10/27/2012 10:00
59126-509 Throttle Lever 2'em Jet Ski JS400 JS440 Kawasaki NOS $24.99 10/27/2012 10:03
59206-502 Throttle Cable Assembly Jet Ski JS400 Kawasaki NOS $24.99 10/27/2012 10:06
59236-504 Bilge Pump Filter Jet Ski JS300 JS400 JS440 JS550 650 Kawasaki NOS $9.99 10/27/2012 10:09
59401-3001 Choke Cable Jet Ski JS300 JS400 JS440 JS550 Kawasaki NOS $26.99 10/27/2012 10:12
92005-501 Grease Nipple Fitting 7'em JS300 JS400 JS440 JS550 Kawasaki NOS $9.99 10/27/2012 10:15
92015-506 18mm Handlebar Nut 3'em JS400 JS440 Kawasaki NOS $21.99 10/27/2012 10:18
92022-106 Turn Signal Washer 9'em H2 H2A 750 Triple Mach IV Kawasaki NOS $13.99 10/27/2012 10:21
92022-204 Foot Peg Washer 12'em Later H1 500 Triple Mach IV Kawasaki NOS $9.99 10/27/2012 10:24
92043-508 Throttle Pin 4 (Four) of them 1976 Jet Ski JS400 Kawasaki NOS $18.99 10/27/2012 10:27
92045-505 Crankshaft Ball Bearing 3em Jet Ski JS400 JS440 JS550 Kawasaki NOS $24.99 10/27/2012 10:30
92045-512 Crankshaft Bearing Jet Ski JS400 Kawasaki NOS $9.99 10/27/2012 10:33
92050-501 Jet Drive Oil Seal 2'em Jet Ski JS400 JS440 JS550 Kawasaki NOS $12.99 10/27/2012 10:36
92050-502 Oil Seal SCY20368 4'em Jet Ski JS400 JS440 JS550 More Kawasaki NOS $24.99 10/27/2012 10:39
92050-507 Oil Seal TCY306210 Jet Ski JS400 JS440 JS550 Kawasaki NOS $9.99 10/27/2012 10:42
92050-508 Oil Seal SCY547410 Jet Ski JS400 JS440 Kawasaki NOS $19.99 10/27/2012 10:45
92065-504 Fuel Tank Gasket 3'em Jet Ski JS400 JS440 JS550 JS650 Kawasaki NOS $9.99 10/27/2012 10:48
92065-516 Magneto Cover Gasket 4'em Jet Ski JS400 Kawasaki NOS $24.99 10/27/2012 10:51
92065-526 Carburetor Gasket 2'em JS300 JS400 JS440 JS550 Kawasaki NOS $9.99 10/27/2012 10:54
92072-521 Fuel Tank Band JS300 JS400 JS440 JS550 Kawasaki NOS $9.99 10/27/2012 10:57
11009-505 Engine Cylinder Base Gasket 10 each Jet Ski JS400 440 Kawasaki NOS $49.99 10/27/2012 11:00
11060-3704 Carburetor Gasket 4 each Jet Ski JS300 JS400 JS440 Kawasaki NOS $9.99 10/27/2012 11:03
110R0690 Cylinder Head Bolt 6x90 9 each Jet Ski JS400 JS440 Kawasaki NOS $36.99 10/27/2012 11:06
13001-506 Standard Size Piston 2 each Jet Ski 400 JS400 Kawasaki NOS $76.99 10/27/2012 11:09
13033-3005 Wrist Pin Bearing 2 each Jet Ski JS400 JS440 JS550 Kawasaki NOS $15.99 10/27/2012 11:12
21039-3003 Starter Charger Brush 2'em Jet Ski JS400 JS440 JS550 Kawasaki NOS $21.99 10/27/2012 11:15
59016-533 Engine Bed Bracket Mount Jet Ski JS400 JS440 JS550 Kawasaki NOS $9.99 10/27/2012 11:18
59086-520 Battery Plate 2'em Jet Ski JS400 JS440 Kawasaki NOS $24.99 10/27/2012 11:21
59201-502 Hull Bumper Jet Ski JS400 JS440 Kawasaki NOS $18.99 10/27/2012 11:24
Jet Ski Assorted Parts JS400 A Must Have Collection 11 items Kawasaki NOS $49.99 10/27/2012 11:27
- 11009-3784 2 GASKET EX
- 13002-505 1 PIN
- 315B1800A 3 NUT 18MM
- 43028-3001 1 DIAPHRAGM PUMP-OUTER
- 43028-3002 1 DIAPHRAGM PUMP-INNER
- 59036-530 1 COVER SIDE GARB
- 59071-516 1 JOINT-STATOR WIRE
- 59346-503 3 DETENT HOOD LEVER
- 92015-507 2 NUT 14MM
- 92065-515 4 GASKET HOUSING
- W56019-001 1 COUPLING AIR
