Entry Description
14700-KZ4-890 VALVE ASSY., L. EX.
14630-ME9-003 ADJUSTER
53172-MJ6-000 BRACKET, HANDLEBAR
14620-413-010 GUIDE, CAM CHAIN
14711-116-000 VALVE, IN.
53172-VM6-000 BRACKET, BRAKE LEVER
14610-HB3-000 GUIDE, CAM CHAIN
14711-329-010 VALVE, IN.
53175-KA3-680 CONTROL LEVER, R.
14611-376-000 GUIDE, CAM CHAIN
14711-152-000 VALVE, IN.
53175-KA5-770 CONTROL LEVER, R.
14711-216-020 VALVE, IN.
14700-KS7-000 VALVE ASSY., L. EX.
53173-435-730 BRACKET
53224-HB3-000 HLDR, STEERING SHAFT
91255-969-005 DUST SEAL (45X68X15)
14611-300-000 GUIDE, CAM CHAIN
53175-MJ4-701 CONTROL LEVER, R.
53175-KA3-731 LEVER, R. HANDLEBAR
14711-087-710 VALVE, IN.
91257-MC7-003 OIL SEAL
14611-312-000 GUIDE, CAM CHAIN
53173-950-000 ARM, BRAKE
91265-HA8-003 RING, SIDE SEAL
53224-HM7-000 HOLDER B
91257-MA2-003 OIL SEAL
91205-333-015 OIL SEAL
91206-428-005 OIL SEAL (34X62X14)
53175-HA6-405 LEVER, R. HANDLEBAR
53175-HA6-680 LEVER, R. HANDLEBAR
53174-KA3-730 HOLDER, L.
91255-461-003 OIL SEAL (37X50X11)
14610-105-691 ROLLER
61111-HA7-670 STAY A, R. FR.
53175-HC4-010 LEVER, R. HANDLEBAR
53175-KS6-671 LEVER, R. HANDLEBAR
91267-371-003 OIL SEAL (43X67X32)
95014-16000 ADJUSTER G, CHAIN
53236-MB1-000 HOLDER, L. HANDLEBAR
91255-HA0-003 DUST SEAL (42X58X11)
53322-HA7-770 BUSH, STEERING PIVOT
95014-19000 ADJUSTER K, CHAIN
91255-HN6-003 DUST SEAL (32X58X10)
91257-463-013 OIL SEAL
91256-HA7-671 DUST SEAL (40X52X7)
91205-362-005 OIL SEAL (20X52X10)
91265-371-003 OIL SEAL (70X90X8)
91265-MB0-003 OIL SEAL (60X80X8)
91206-413-003 OIL SEAL (34X63X12)
91209-371-003 OIL SEAL (27X43X9)
61111-HB9-000 STAY, R.
91251-HC5-005 OIL SEAL (38X64X11)
91250-HA7-671 DUST SEAL (24X47X15)
91252-HB5-003 DUST SEAL (44X62X7)
91252-HM5-630 DUST SEAL B 44X62
91262-MG9-003 OIL SEAL (39X56X7)
91255-463-305 OIL SEAL (39X52X11)
91201-HM7-003 OIL SEAL (32X52X8)
91253-442-003 DUST SEAL (30X52X7)
91251-HB3-003 DUST SEAL
53173-KA3-710 HLDR, LEVER BRACKET
91202-HP1-671 OIL SEAL (30X44X7)
61101-HP1-000 STAY, R. SHROUD
61102-HP1-000 STAY, L. SHROUD
90451-141-000 WASHER (13.5MM)
91252-HA0-003 OIL SEAL (35X49X6)
91252-HA7-671 OIL SEAL (22X40X9)
91201-MEB-671 OIL SEAL (38X52X7)
91252-HM8-003 DUST SEAL (43X58X10)
91203-292-005 OIL SEAL (8X34X8)
53175-087-760 LEVER, R. HANDLEBAR
91252-HM5-A11 DUST SEAL (42X58X8)
91261-MB0-003 OIL SEAL (34X50X7)
91261-ME9-005 OIL SEAL (27X43X7)
91201-300-003 OIL SEAL (30X42X8)
91261-ME4-003 OIL SEAL (30X45X7)
91259-HA7-671 DUST SEAL (25X47X7)
91202-283-013 OIL SEAL (18X28X6)
61102-HC0-010 STAY, L. FR.
91201-KS6-004 OIL SEAL (26X37X7)
91202-250-000 OIL SEAL (14X25X7)
91257-VM0-004 DUST SEAL (28X42X6)
61303-VM6-000 NUT, HEADLIGHT CASE
53173-376-000 HLDR, LEVER BRACKET
53173-KN5-670 HLDR, LEVER BRACKET
91271-HC4-004 OIL SEAL (42X51X7)
53177-HA0-680 CVR, L. HANDLE LEVER
53314-HC4-000 CAP, STEERING SHAFT
53173-958-000 HLDR, LEVER BRACKET
91205-943-003 OIL SEAL (27X37X7)
91271-ME4-003 OIL SEAL (43X52X7)
91205-283-015 OIL SEAL (33X57X7)
90421-HA2-010 WASHER (23X48)
91205-957-004 OIL SEAL
91202-HB3-003 OIL SEAL (22X32X7)
91205-950-003 OIL SEAL (25X42X7)
91205-VM6-003 DUST SEAL (23X35X7)
91256-HC5-003 DUST SEAL (38X50X7)
91252-HC5-003 OIL SEAL (22X48X7)
91202-459-771 OIL SEAL (31X43X8)
91259-KS6-831 DUST SEAL (24X37X7)
91257-MAY-003 DUST SEAL (28X42X8)
90451-383-000 WASHER (34MM)
14626-383-000 COLLAR
91257-HB3-003 DUST SEAL (35X20X7)
61103-VM5-000 WASHER
91209-HN5-671 DUST SEAL (40X58X9)
91258-ML7-003 DUST SEAL (45X55X5)
91211-KA3-741 SEAL, WATER PUMP
90481-HC4-000 WASHER, TAPER
90481-958-000 WASHER, TAPER (32MM)
91201-028-005 OIL SEAL (13X22X5)
91258-HB3-003 DUST SEAL (37X25X6)
91216-PA0-003 OIL SEAL (22X35X7)
91207-329-003 OIL SEAL (15X27X7)
61104-422-000 COLLAR, SETTING
61104-444-000 COLR, FENDER SETTING
90403-422-000 WASHER (10MM)
91202-286-025 OIL SEAL (22X35X6)
90443-HA0-000 WASHER, LOCK (7MM)
91207-357-000 OIL SEAL (20X34X7)
91201-216-005 OIL SEAL (20X52X9)
90403-HA7-670 WASHER (20MM)
91213-PD2-004 OIL SEAL (29X45X8)
91208-HF7-005 DUST SEAL (14X20X4)
90403-ML4-610 WASHER (10MM)
91205-360-000 OIL SEAL (16X28X7)
91201-943-013 OIL SEAL (20.8X35X8)
91201-030-033 OIL SEAL (20X34X7)
91201-283-005 OIL SEAL (12X25X4.5)
91201-362-000 OIL SEAL (12X25X7)
91202-426-003 OIL SEAL (12X25X4.5)
91201-415-013 OIL SEAL (17X28X7)
95012-13000 BAND B2, BATTERY
91256-096-651 OIL SEAL
91201-HA8-682 COVER, SEAL (20X4)
90446-HC0-000 PLATE
91201-427-003 OIL SEAL (12X20X6)
95014-10010 ADJUSTER S, R. CHAIN
91251-444-000 DUST SEAL
90437-611-000 WASHER, PLAIN (12MM)
95015-54000 PIN D, JOINT
91203-023-020 OIL SEAL (14X26X7)
91201-965-000 OIL SEAL (12X22X5)
91208-KB4-671 OIL SEAL
91265-HB9-671 DUST SEAL, FR.
90451-HM7-000 WASHER (20MM)
61302-HB7-000 RUB, HEADLIGHT CASE
95011-52000 RUBBER B
90446-357-000 WASHER (17.2MM)
91202-HC0-003 OIL SEAL (10X20X5)
91201-324-023 OIL SEAL
91201-147-003 OIL SEAL (15X25.5X7)
61304-292-000 COLLAR
90402-HN6-000 WASHER, SPRING
95010-16001 CAP A, LEVER
61304-958-003 NUT, SPECIAL (6X7)
91206-286-013 OIL SEAL (14X28X7)
90443-107-000 NUT, CAP (8MM)
53174-KS6-831 SPRING, BRAKE LEVER
61142-001-000 METAL, FR. (LOWER)
90401-437-000 WASHER, PLAIN (10MM)
95014-75140 SPRING, CLUTCH
94011-18000-0S NUT, CASTLE (18MM)
90474-333-000 WASHER (8MM)
90456-MA6-000 WASHER (25MM)
61104-KB7-900 COLLAR
90451-GF6-000 WASHER (12MM)
90441-425-000 WASHER (10MM)
90441-MC0-000 WASHER (7MM)
90441-028-010 WASHER (6MM)
90471-580-000 GASKET (8MM)
90456-053-000 WASHER (20MM)
93700-06070-0G SCREW, OVAL (6X70)
90442-028-000 WASHER (8MM)
91202-KA3-711 OIL SEAL (10X17X4)
93404-10025-08 BOLT-WASHER (10X25)
53177-KS5-700 CVR, L. HANDLE LEVER
90462-235-000 WASHER, LOCK (20MM)
94012-10000-0S NUT, CASTLE (10MM)
94050-10000 NUT, FLANGE (10MM)
94050-10080 NUT, FLANGE (10MM)
93500-03035-4J SCREW, PAN (3X35)
95700-06022-08 BOLT, FLANGE (6X22)
93500-05032-0B SCREW, PAN (5X32)
93500-06075 SCREW, PAN (6X75)
95002-02100 CLIP, TUBE (B10)
95701-06012-08 BOLT, FLANGE (6X12)
94021-08020-0S NUT, CAP (8MM)
61103-HM5-850 RUBBER, FR.
93500-06090 SCREW, PAN (6X90)
95701-08016-07 BOLT, FLANGE (8X16)
93500-04055-4J SCREW, PAN (4X55)
95701-08016-00 BOLT, FLANGE (8X16)
94021-10000 NUT, CAP (10MM)
95700-06025-08 BOLT, FLANGE (6X25)
93500-06014-02 SCREW, PAN (6X14)
90475-703-000 WASHER C (8MM)
90486-028-000 WASHER
95700-06018-08 BOLT, FLANGE (6X18)
95700-06035-00 BOLT, FLANGE (6X35)
93700-06010-02 SCREW, OVAL (6X10)
94071-08080 NUT-WASHER (8MM)
93600-08022 SCREW, FLAT (8X22)
93893-05016-07 SCREW-WASHER (5X16)
95701-06022-00 BOLT, FLANGE (6X22)
95701-08014-07 BOLT, FLANGE (8X14)
93700-06045 SCREW, OVAL (6X45)
93700-05016-0B SCREW, OVAL (5X16)
93500-06028-0A SCREW, PAN (6X28)
93700-04012-0B SCREW, OVAL (4X12)
95701-06012-07 BOLT, FLANGE (6X12)
94050-08000 NUT, FLANGE (8MM)
93600-06035 SCREW, FLAT (6X35)
93893-06012-07 SCREW-WASHER (6X12)
93715-06040 SCREW, OVAL (6X40)
93892-05012-08 SCREW-WASHER (5X12)
93894-05012-07 SCREW-WASHER (5X12)
93500-04050-0B SCREW, PAN (4X50)
93500-05030-0A SCREW, PAN (5X30)
93500-06018 SCREW, PAN (6X18)
93500-06035-02 SCREW, PAN (6X35)
93600-06025 SCREW, FLAT (6X25)
93700-03025-3B SCREW, OVAL (3X25)
94021-04070-0S NUT, CAP (4MM)
93500-04055-0B SCREW, PAN (4X55)
93700-06016-0A SCREW, OVAL (6X16)
93700-06016-0B SCREW, OVAL (6X16)
93500-04050-0A SCREW, PAN (4X50)
93500-06035 SCREW, PAN (6X35)
93500-06080 SCREW, PAN (6X80)
93700-06020 SCREW, OVAL (6X20)
93700-06030 SCREW, OVAL (6X30)
93892-05020-07 SCREW-WASHER (5X20)
93500-06042 SCREW, PAN (6X42)
93700-05016-0A SCREW, OVAL (5X16)
94001-08000-0S NUT, HEX. (8MM)
93500-06012-07 SCREW, PAN (6X12)
93500-06020-02 SCREW, PAN (6X20)
93600-06012 SCREW, FLAT (6X12)
93600-06020-0A SCREW, FLAT (6X20)
94001-08020-0S NUT, HEX. (8MM)
94031-10000 NUT, HEX. (10MM)
90478-700-000 WASHER A (6MM)
95701-06014-07 BOLT, FLANGE (6X14)
93500-06012-08 SCREW, PAN (6X12)
93903-24380 SCREW, TAP (4X12)
93500-04010-0H SCREW, PAN (4X10)
93500-05010-0H SCREW, PAN (5X10)
94101-04800 WASHER, PLAIN (4MM)
93500-06030 SCREW, PAN (6X30)
93500-04006-0G SCREW, PAN (4X6)
93500-04012-0A SCREW, PAN (4X12)
93500-06020-07 SCREW, PAN (6X20)
93500-03010-0A SCREW, PAN (3X10)
93700-06010 SCREW, OVAL (6X10)
93700-05020 SCREW, OVAL (5X20)
93500-06016-00 SCREW, PAN (6X16)
93700-05025-0A SCREW, OVAL (5X25)
94021-04000-0S NUT, CAP (4MM)
93600-04012-1A SCREW, FLAT (4X12)
93892-04006-00 SCREW-WASHER (4X6)
